Trektop nx leaking, do I have this right?
Originally Posted by Patman
I had this problem and I fixed it with some adhesive weather stripping from home depot. It's squishy foam, and I stuck it to the plastic pillar just behind where the soft top corner is. I also put some of it on the plastic trim piece while it was folded, the straightened out the trim piece, compressing the foam and creating a better seal.
On a side note, I had to get a warranty-replaced corner panel, and the new piece has a rubber weather seal sewn into the top that does a good job of sealing out the water. Apparently, bestop realized the problem and created a fix (I also heard that the newer trek tops come with a factory style tailgate bar?). Perhaps you could complain to wherever you bought it and get two new panels?
I know when I installed the roof there was a good deal of adjustment to the brackets in that area, any chance that could be a source of remedy?
It's fine, all trek tops have that. Yes it leaked when sprayed with a hose because of direction of spray. Just tighten it everywhere and call it good. It is normal. My top is the exact same w/ no leaks except when she gets a bath.
