Trouble filling Diff fluid
Old 01-07-2012, 05:53 PM
sneck's Avatar
yeah, after reading the jk writeup, it looks like the riddler fill holes are almost in the same spot as the factory, so i'm just going to get a pump, and pump till it squirts out.
Old 01-07-2012, 05:55 PM
Battlefrog's Avatar
The nozzle on most diff fluid bottles make it easy enough without a pump. The angle or placement of filler hole on the riddler covers makes it pretty easy....
ID:	260822   Click image for larger version
Old 01-07-2012, 06:01 PM
hagausaf's Avatar
I just filled mine up until I was able to feel fluid when my pinky finger felt the fluid inside. Did that for both diffs and I also have Riddler D44 covers
Old 01-07-2012, 06:03 PM
Battlefrog's Avatar
My riddlers were like a bottomless pit when I filled the rear...
Old 01-07-2012, 06:06 PM
hagausaf's Avatar
Same here. I used damn near 5 quarts of Royal Purple overall
Old 01-07-2012, 06:12 PM
Battlefrog's Avatar
I use Lucas and had to make 3 trips to advanced... That was an expensive fluid change for you haha...
Old 01-07-2012, 06:19 PM
sneck's Avatar
yeah I guess I dont have enough lift in the rear, because i cant go under the bar, the muffler gets in the way, and i cant go over the bar, because its too steep. so im gonna have to shuffle off to autozone at some point
hagausaf's Avatar
yea about 90 after my military discount. Not unbearable seeing as I'd just spent a ton getting regeared, sleeved/gusseted and such. Cant go cheap on the oils.
Old 01-07-2012, 06:20 PM
tslewisz's Avatar
If you filled that rear Riddler til it barfed fluid out the fill hole, it's over filled. You only need to fill it a little over the bottom of the axle tube.
Old 01-07-2012, 06:24 PM
hagausaf's Avatar
correct and this is why I use my pinky as a measuring stick. If you fill it too high then it'll come out your breather and smell like shit or in my case like Royal Purple
Quick Reply: Trouble filling Diff fluid
