Trouble re-installing short side axle shaft
Old Feb 12, 2011 | 09:13 AM
ROKLIMO's Avatar
Default Trouble re-installing short side axle shaft
Replacing balljoints, and can't for the life of me get the short-side axle shaft back in. The splines are somehow magnetized and want to stick to the inside of the tube. I can get it by the oil seal with some difficulty, but no dice on into the diff. Any ideas?
Old Feb 12, 2011 | 09:16 AM
wayoflife's Avatar
JK-Forum Founder
magnetized?? pull your axle shaft out and shine a light into the housing. if you look real carefully, i'll bet you'll see a plastic ring inside near the axle seal. you need to reach in there with something like a coat hanger and remove it as it's preventing you from reinstalling your axle shaft.
Old Feb 12, 2011 | 09:18 AM
ROKLIMO's Avatar
Yep magnetized. I will check for the plastic ring. Thanks
Old Feb 12, 2011 | 09:19 AM
wayoflife's Avatar
JK-Forum Founder
okay, just checkin - either way, that shouldn't make a difference and your axle shaft should just ramp up and go into your carrier. the plastic ring getting in the way of the shaft is a common problem and something that's easy to over look.
Old Feb 12, 2011 | 09:48 AM
ROKLIMO's Avatar
You were right on! I got extra lucky and had to remove two of them...
And here is visual evidence of the magnetized axle shaft...
Thanks again
Old Feb 12, 2011 | 10:27 AM
wayoflife's Avatar
JK-Forum Founder
Thanks again
LOL!! i believe you, it's definitely magnetized
still, it shouldn't make a difference in the installation of your shafts.
glad that i was able to help you out
