TRUE Cold Air attempt
Old Aug 6, 2008 | 09:10 PM
  #41
deconstructionist's Avatar
Originally Posted by pastorsteve
That's exactly what the new military Jeep J8 is doing. All you would have to do is replace the military scoop with one that's asthetically pleasing, add an up-tube from the airbox to the scoop and viola.
Yeah. Thanks for the pic...I remember seeing this a while ago and what led to me thinking up *something*
I did manage to ONLY find a 90 degree elbow today....got it painted and should be going on friday or saturday
Old Aug 6, 2008 | 09:38 PM
  #42
pastorsteve's Avatar
Riddle me this any of you arm-chair-engineers. Wouldn't the scoop be more effective and bring in less water if placed at the back of the hood and faced the windshield?
Wouldn't it would take the air coming down off the windshield and run it right into the scoop like the mid-70's Trans-Ams?
Old Aug 6, 2008 | 10:18 PM
  #43
Roxster's Avatar
Just keep in mind that the top of the air box is not where you'd want to tie in... that would bypass the filter. I think you'd get most of the benefits of a cold air intake by simply positioning a scoop over the airbox, but not dealing with the extra work and hassle of trying to tie it in and compromising the integrity of the factory air box, etc. The scoop would still provide a path to cooler air, while also giving the hot air under the hood a chance to escape. In the event that water gets into the scoop, it would just harmlessly run down on top of the air box on its way to the ground.
Old Aug 7, 2008 | 04:57 AM
  #44
RedneckJeep's Avatar
Look at post 29. Duh.
Old Aug 7, 2008 | 03:33 PM
  #45
rcwade's Avatar
FWIW I used to make some "Ram Air Blinkers" I would put mesh on the blinkers and route a tube to the airbox. Did a good job, but also water was an issue. This was in a VW>
Old Aug 8, 2008 | 10:06 AM
  #46
neopj3's Avatar
if you reversed the intake hose to the bottom of the air box then you could route a scoop off the top. doesn't the river raider system work like this? there's enough room to route a pipe stright down inside the engine bay to near the axle. just check for clearence and you WILL need to make/buy a bi-pass filter/valve for water crossing. other wise you'll hydro lock. what about relocating the intake to where the vent thingy is in front of the wind shield? what's that for anyway????????
Old Aug 8, 2008 | 10:39 PM
  #47
Dont know....
Yes...Still worrying about a hydrolock situation
Dont know.....
UPDATE:
The 90 degree elbow did NOT work. Same situations as before-- stoops down tooooooo low much like in this shot from before.
So for now the fully ruberized one is back on again..............
May just be time to start considering entirely different routing scenarious that you guys have mentioned
Old Aug 9, 2008 | 02:29 AM
  #48
pearl-drum-man's Avatar
And post #16
Old Aug 9, 2008 | 06:15 AM
  #49
Originally Posted by pearl-drum-man
And post #16
Yeah...what you said.
Old Aug 9, 2008 | 06:30 AM
  #50
jkbandit's Avatar
what you all said, with this
