True Flow XDI + MAGNAFLOW
Old Jan 30, 2009 | 07:35 PM
Lo2aY's Avatar
Originally Posted by Adam3612
So both of you have the True Flow XDI and Magnaflow exhaust installed and are happy with the setup? I just want to make sure, I plan on installing both in the very near future and was wondering how well everything will mesh together. Have you noticed any HP/Torque increases and if so where at on the power curve?
as I said earlier i'm happy with the setup. just not the sound. but as mcaden said. It hopefully might get a bit loader.
Both companies offer really good customer service and tech support. I called XDI for some questions about the installation and the guy who actually did make the intake was on the phone. he told me that I should get 10hp on the intake. and the guys at magna said the same thing on hp and 12 on tq
so 20 hp. which I don't think is significantly noticeable but it's there
The intake has an amazing sound, it looks sexy under the hood. and I think it's worth the dime
cheers
Old Jan 30, 2009 | 07:44 PM
Adam3612's Avatar
cheers
Yeah from the install pics I seen I've gotta agree, they do look good. The magnaflow seems like one of if not the best exhaust out there for the JK. Is the magna muffler smaller than the stock? Thanks for the info man
Old Jan 30, 2009 | 08:09 PM
mcaden's Avatar
Default Magnaflow Muffler - Smaller than Stock
Yes, the Magnaflow muffler is considerably smaller than the stock muffler and once the stock exhaust is out, which is a trick in itself, it is a breeze to install. I even did the install at night in my driveway (check out Magnaflow's website).
As for power gains, mine is a 2 door and I remember hearing the intake really kick in between 3-4 RPMs. After I installed the exhaust it seemed to increase through out the band. However, I have not dynoed her to see where she is at in HP or Torque. Right now, my performance is a little better due to the cold weather but this should change once spring arrives and the temp increases.
With a 4 door you may not see a significant gain in power depending on your setup. I have since lifted her 3.5 inches and added 35s, which has dropped my power, especially in the higher gears (she tends to crawl if I shift too soon).
I would strongly suggest the exhaust for anyone who is looking to upgrade as you will receive some type of gain even if it is not what is quoted on the manufacturers site. Magnaflow really does make a high quality product and its got a lifetime warranty, you'll never need another exhaust.
Hopefully, you'll like what you hear.
Old Jan 30, 2009 | 08:28 PM
mcaden's Avatar
Thanks that's what I was told by Magnaflow. I'm hopping thats true
I have an Issue with my Engine ticking all the time. I don't know if it's the same as the headers crack that some people were complaining about here or not. My dealer replaced some engine parts. but still no luck. noise is still there. and on a cold start it is super Irritating. It gets really load and then back to the same old crappy clicking!
I'm sorry, but I am not familar with the ticking in the engine. If you do happen to have a crack in your header, you can replace them with Banks' TorqueTube Headers. They are little pricey but come with a limited lifetime warranty and should add a little bit of sound to that exhaust. You can check out the installation guide & owners manual on their website. This just might be my next power upgrade to make up for the lift and tires.
The only noise issue I had coming from the engine compartment was a whistle from the intake. A few months after the installation it went way and has not come back.
Old Jan 30, 2009 | 11:19 PM
Lo2aY's Avatar
your right but the tip it's self is longer. mine is having contact with my PureJeep rear bumper. So I need to find a way to fab it.
Old Jan 30, 2009 | 11:27 PM
Lo2aY's Avatar
This could possibly be the fasteners for the intake. make sure they are all in place and tight.
last time the dealer checked on my Jeep for that ticking noise. they said it was the lifters! some of them were not set correctly from the factory. so they replaced them. the ticking didn't go away. so they said oh it's the timers they are not set correctly. every time I go in it's something new! this issue was noted on my jeep since the 3rd day of owning it. that was on dec. 14th 2007 we had three chrysler field engineers inspect it. and all they said is that it's normal
what they don't realize is that if they start another JK. they will not hear that freaking TICK!
I'll have some sound clips of it and start a thread in the stock section. I hope no one has the issue, but if so. it will be there for reference and or maybe get some help from the cool guys on the forum
Old Jan 31, 2009 | 04:30 AM
afoulk's Avatar
If the ticking is really bad when its cold, and gets a little better once it heats up, its almost gotta be a crack in one of your exhaust manifolds.
Old Jan 31, 2009 | 07:36 AM
Adam3612's Avatar
I feel alot better about ordering both of them now I've seen a couple of youtube clips for the XDI and the magnaflow on a JK, they sound mean when you stomp on the gas.
Old Feb 1, 2009 | 10:22 AM
Lo2aY's Avatar
Originally Posted by SONIC
As far as this goes its a really easy fix. Get yourself a blowtorch, heat up the metal hangers and bend them a bit
you can get a blowtorch for about 20 bucks if you dont have one already
and yeah id be interested int he exhaust whenever you get a hemi
you got it
afoulk
I'm hopping so. I traced the sound. and it seems like it's more on the passenger side.
Adam3612
It got a bit loader yesterday, Its sounds great!
