TrueTrac Eaton's Front and Rear
I’ve been thinking about putting the True Trac in the front when I re-gear also. I've heard a lot of good things about them but haven't talked to anyone running them in a JK yet. Not in to serious rock crawling and mostly stay on medium type trails. The Factory LSD in the rear has been great for the type trail we do. I was thinking this would be a good upgrade for the front when I re-gear. I've thought about the Aussie but I'm afraid of the whole ratcheting thing since this is my DD.
I have been running the Eaton Truetrac both in the front and rear diffs for about four months. I have a 6-speed X with 4.88s. So far, I have been impressed with them although, I have only done moderate trails with some difficult slick rock. Unfortunately, we have been getting a lot of snow here this year, the only upside of which is the Truetracs have worked great.
Just to answer nangulators question, all you need for the front d30 is a standard d30 truetrac, I installed mine earlier this year and likewise with 8633 I don't do extreme rocks or trails, but for my weekend warrior you can definately tell a boost in front end traction.
On a side note. I think lunchbox lockers are a great option as well and the only reason I landed on the truetrac was that re-gearing from 3.21 to 4.10 I had to change out my front carrier anyways, so opted to just install a truetrac
I got to test out my TrueTrac in the snow down in central VA today and it did great. I have had it installed for about a week along with an ARB in the rear and engaged 4wd for the first time since the regear today. The TrueTrac operated completely transparent but it seemed that I had an improvement in traction running uphill on unplowed roads. I will provide a trail report in the next month or so when I can get back up to Rausch Creek.
bump...
I am going to be purchasing gears soon and need some info on lockers. I am debating whether to keep my diffs open like they are now (stock X) or change up my plans and add in lockers.
Dumb question alert: How do I know if I have the LSD from the factory?
To update on the front TrueTrac, I have been driving in the 2+ foot snows last weekend and today and have felt the front LSD engage a couple times and it seems to be helping with traction. I have been able to push through completely unplowed snow with no issues at all while in 4 High. I also felt it engage Saturday trying to get in my driveway which had a 4 foot wall in front of it from the plow. I will give another report when I can get back out to Rausch Creek to truly test it.
BTW, I still have not tested the rear ARB locker that was installed with my gears. I am waiting to get the first 1000 miles on the gears before engaging. I can't wait to hit some rocks and mud with the TrueTrac in the front and locker in the rear.
lift the rear two tires up off the ground and rotate a tire, if both rotate in same direction you probably got the factory LSD in the rear
