Tuffy conceal and carry security drawer
Good advise but it is not for a firearm. I plan on using it for wallet, cell phone and passport along with other valuables when I am surfing. Park the jeep, throw everything in there and just have my surf key in my wetsuit. I guess drilling a hole in the floor isn't exactly difficult but it would suck if i did it in the wrong spot lol.
I thinking the method would be to install it lose with the seat bolts, mark where the hole should go, take everything back out, carefully drill out with twist bit, and bolt everything back in place. Maybe use some silicone around the bolt hole and some rattle can to prevent any corrosion or rust.
The drawer fits both JK and JKU. I have it in my 2010 2dr. It works great. When I installed it, I only used the 2 front bolts and the carpet kept the back end from rattling. In the process of pulling the carpet and bed lining, I added the rear bolt.
I'm pretty sure that a thief could quickly defeat the small bolt at the back. It's really just to keep the drawer from rattling.
If you are asking about the quality of the locks, they both seem decent. Security of key vs. combo? The combo is only 3 numbers, how long would it take someone to spin them enough times to guess the combo?
Then again, how long would the key lock last against someone who knows how to pick locks? Or how long would it take to pull the seat bolts, find out that you can't pick up the box, and crawl underneath to cut off the 3rd bolt? Or just load the jeep onto a flatbed?
I guess the way I look at it is that these drawers are not a replacement for a safe deposit box at my bank. It is a security drawer IN my jeep, and my jeep can be stolen...
Hell, why lock your doors then?
"OPTIONAL SECURITY STEP
WARNING! - Make sure that there is nothing under the vehicle that will be damaged by the drill bit when
drilling. The exhaust is located in that area, be cautious not to touch it when hot.
For additional security remove the drawer from the enclosure (See note above). Mark the spot in the
vehicle floor under the hole in the bottom of the drawer enclosure and drill a 3/8” hole. Fasten using the
included bolt #8.2, washer #8.3 and Nut #8.1. It is recommended to use silicone sealant on any drilled "
I recommend getting the combination lock for your purposes (wallet & keys) while surfing. I use the key-lock myself so that I can access the drawer while sitting in the seat. I carry the security drawer key on a quick disconnect ring. The combination lock is convenient - but it can be difficult to see the numbers and open quickly. 2-cents. It's a great product.
With just the two bolts, the drawer basically hangs and mine rattled some- especially when something was in it. I threw a tool box drawer liner in there, which helped, but then I cut a piece of pipe insulation, stuffed it under the back end and the rattle completely disappeared.
Thanks everyone for the comments. I picked one up today and will install next weekend. I'll update the thread when I do the install. I plan on also ordering the combination lock. It appears that this is not a seperate unit but rather an add on feature to buy separately? Is this correct?
The whole "do it right" concept.....
The 3rd (and ONLY) secure bolt adds all of 10mins total to the install...maybe. As mentioned, it's the only one that cannot be removed unless you have access to inside the box. In other words, it's the ONLY security measure in place to keep the box from getting stolen with nothing more than a wrench or socket/ratchet. Battery powered ratchet: < 2 minutes, tops. If you keep stuff in there unimportant enough that you don't care if you reward a thief with 3 nefarious minutes, then why have it anyway?
If you're keeping a firearm in there and don't want to spend the little extra measure it may take to keep your firearm out of evil hands, you should reconsider whether you should even be carrying at all. Add a gigantic "stupid factor" if that's the case and you're rolling with a soft top or none at all.
Your argument is classic in the Gun Control talking points. The arguments go like this....
"it is common sense to lock your gun up to make it safe that others wont steal it".
"you should never need a clip that has more than 10 rounds".
"You must store the ammunition in a different location from the weapon".
"Guns kill people".
"Anyone buying a gun should wait 30 days".
"No real hunter would ever need an AR15".
In the mean time, all of us law abiding citizens are at the mercy of thieves and miscreants with no way to defend ourselves. Where you take away citizens basic rights, it benefits only those who have no problem with breaking the laws. Just look at DC, Baltimore and Chicago to see how well those "common sense" laws work.
Personally I carry my firearms with me because it is no use to me locked in the vehicle. If every other Jeeper did the same, none of us would have to lock our Jeep. Nor would we have to spend our hard earned money to achieve some super level of responsibility because we only want to be able to defend ourselves. Then the world would be a much safer place.
