Under Hood Light Solution!
Old Mar 7, 2008 | 05:53 AM
jkkat's Avatar
The hood has a HUGE hinge
Old Mar 7, 2008 | 05:58 AM
hiteck's Avatar
Originally Posted by USAF_GroundRat
Also... the first JKs came with hood lights.
My X has an under hood light manuf date 10/06.
If they were available at one time then there must be a part number for it and would more than likely plug right into an existing harness
Old Mar 7, 2008 | 06:10 AM
hiteck's Avatar
I'm at work and its currently snowing but I'll take a look after work (noon) and try to get a pic as well as a PN.
Old Mar 7, 2008 | 06:28 AM
whpony96's Avatar
No harness in my 08 anywhere for a light and none under the dash for the footwell lights either..
Old Mar 7, 2008 | 06:31 AM
whpony96's Avatar
Not to mention this fix I found will still work If you battery is dead in your jeep! LOL
Dr.McNinja's Avatar
Originally Posted by jeepnxj3
true, but they are bolted to the body at the hinges.
How's your hood attached then? Cuz mine is bolted to the body at the hinges just like my doors.
I think the door electronics ground runs through the harness.
Old Mar 7, 2008 | 06:35 AM
whpony96's Avatar
The harness has its own ground wire. The hinges move and that is not a solid contact.
Old Mar 7, 2008 | 11:50 AM
hiteck's Avatar
Chrysler P/N:56021441
Vendor ID: 588832D
Here's a some pics:
Mounting bracket with plastic pushin
Back side of light housing that clips to above bracket
Underhood Mounting Location
Light Mounted Underhood
Old Mar 8, 2008 | 03:26 PM
USAF_GroundRat's Avatar
Do a search on hood lamp... there have been many discussions on this back when this board was started. Basically, Chrysler deleted this 1000 dollar wiring harness which had the footwell and under hood lights.
