Upgraded fuel pump?
Are there any options for an upgraded fuel pump for the 07-11 JK? For those of us running forced induction I would like the peace of mind if there was an upgrade option now that it seems to be time to replace the pump anyways.
The flow from the factory pump can run a small V8. The pump and sending unit are all in one package but you can add any stand alone pump with tank modifications if you want but nothing is out there to drop and go in the factory location.
Yup i did this but also had to add a fuel pressure regulator as to my knowledge thats also in there all in one set up.
You could easily install a fuel pump like the E2000 at the front of the tank where the tanks lines meet the jeeps lines. The JK uses a very common 3/8" push lock fitting.
Should you? No. There is no reason at all.
~Jeff
