Upper Control Arms causing DW?
Old Dec 27, 2010 | 10:31 AM
jason1707's Avatar
Default Upper Control Arms causing DW?
Got a 08 4 door Sahara - put a 2.5" Teraflex coil lift on, still have stock tires/wheels. I started getting DW/shimmy at 75mph while hitting a bump. The outer edge of my tires on the front were worn pretty bad from the caster being off - the DW really didnt start untill I noticed the outside was wearing unevenly. I rotated tires and put on a new stering stabilizer and never had it again. Well this morning it happened to me 3 times - 1st @ 75, then around 65 and again around 60ish. I put on some adjustable LCA's but have not had it aligned yet but I did notice the outer edge of the tires are wearing unevenly suggesting my caster is still off. I went and inspected everything on the front end just now and everything is tight except the front control arms at the axle. I can see a little bit of play on the axle end when yanking on it and can see a small gap between the bushing and the axle mount. Is this more than likely my culprit? Everything is torqued down to specs as well.
Old Dec 27, 2010 | 10:43 AM
mkjeep's Avatar
Camber and toe will affect your tire wear along with bad ball joints, bad shocks.
Castor will not, unless you have one arm adjusted a good bit longer on one side vs the other, still it wouldn't be castor, it would be cause one side is uneven. Although, loose CA's can contribute to the prob . Have you put it on an alinement machine and got your specs.
Old Dec 27, 2010 | 10:51 AM
jason1707's Avatar
Well I've never heard any metal clanking like that guys but its very loud and feels like the tires are bouncing like that. Dont have to come to a complete stop - can slow down to about 40 and it goes away.
Old Dec 27, 2010 | 11:08 AM
jason1707's Avatar
Yeah I got that write up set as a favorite just havent done all of them yet. The last time this happened I did check all bolt holes and nothing was ovaled out and then everything was retorqued to specs. Could this be happening b/c of my tires being so $hitty? B/c the 1st time this happened to me I rotated the bad ones to the back and it went away. But now that the fronts are worn more its happening again - could the tires cause it?
Old Jan 5, 2011 | 12:35 PM
jason1707's Avatar
Well got new tires and alignment done this weekend and driven on the highway twice now and nothing. Hopefully i'm good to go. thanks for all the help!
