Usable Body Lift
Currently running a 2.5" TF coil kit w/ 35's. I want to verify an idea floating around in my head..
First off I've grown to like the stock flares and do not like the cut look.
I've read that body lifts do not improve suspension characteristics, BUT...
If I were to install a 1" BL, extended brakelines, and reduce my bumpstop height(or remove them), it would essentially allow more uptravel for improved flexing, correct?
Thanks
Thanks
Provided your shocks will allow for it, yes. That also assumes that when you flex now that your tires touch the fenders. Also make sure that your tires don't come in too close of contact with any sharp metal in the fenderwell. If you have a manual (supposedly) the body lift will not work.....supposedly.
