Using 4 jackstands.
Old Aug 26, 2014 | 05:23 AM
ronjenx's Avatar
Another thing to consider....
Some jack stands are rated for a pair. Some are rated for each one. Read the paperwork carefully.
Old Aug 26, 2014 | 09:16 AM
Mark Doiron's Avatar
Really? That's just downright dangerous. But it might explain a pair of jack stands that are rated for 2-1/2 tons that I received for "free" with a floor jack I bought that look downright wimpy compared to my other jack stands that are a couple decades old.
Old Aug 26, 2014 | 01:02 PM
MMXJKU's Avatar
How you are supporting your jeep is also a consideration. 3 ton stands should be good for supporting by the axle. If supporting by the frame use at least 6 ton. Either way do not extend the stand all the way.
Old Aug 26, 2014 | 01:30 PM
nthinuf's Avatar
That is one of my concerns also. I would much rather use a taller 6-ton stand sitting a few notches down from its full height, rather than a 3-ton stand stretched up as far as it will go.
Old Aug 26, 2014 | 10:12 PM
lkjk's Avatar
That doesn't make any sense at all, lbs are lbs, the weight is the same if they are under the frame or axle, or skidplate or wherever. the only way it would see less weight is if they were higher and the opposite wheels where on, pushing more weight onto the wheels.
Otherwise disregard the noise about frame vs axle, and if they weren't meant to extend all the way they wouldn't be made to.
Old Aug 27, 2014 | 12:21 AM
Sahara_Maverick's Avatar
I already did several projects (e.g. changing the suspension, brake pads, etc.) where I held my Jeep using four jacks either by the frame or suspension without any issues.
Mark's advice about the tires is great. Another thing I do is shaking the Jeep a bit (just enough) to see if anything moves before I get under it.
Old Aug 27, 2014 | 04:32 AM
ronjenx's Avatar
I think what he is getting at is frame support usually requires a taller jack stand to keep the tires off the ground.
Old Aug 27, 2014 | 04:42 AM
Collyn's Avatar
Man. Since I lifted my jeep with 3.5"'lift and 35's, I haven't needed jack stands to get under it for anything. Haha. Changing the oil? Just get the creeper and roll under it. Lol. Cleaning mud chunks. Just get on the old clothes and drag the water hose under it. Now getting the window clean and putting up the top is different. I usually have to climb in to wash the front window when I have the top back.
Old Aug 27, 2014 | 06:07 AM
Rob 12B1P's Avatar
Yip, my 3 tons wont reach the frame anymore, 3" Lift and 37's.
