Viair question
Old Jul 6, 2013 | 02:40 PM
lowendrider's Avatar
Default Viair question
Excuse my ignorance but I have no questions on adding a simple onboard air setup. I want to mount a Viair compressor for the sole purpose of airing up my tires after a trail ride. I want to mount the compressor and run a hose with airchuck to the front bumper. Would there be anything else I need? Is it just a matter of wiring the compressor with an on/off switch (with the appropriate relay and fuse)?
I've noticed the systems that use a tank also have a pressure switch which kicks the compressor on when the tank is below a certain psi...without a tank and this switch what does the compressor do when you turn it on...just run and run or will it still shut off on its own?
Again, as you can see from the questions, I'm no compressor or wiring expert, just trying to piece together a simple and reliable system and do it right.
Old Jul 6, 2013 | 03:17 PM
Nbjeep's Avatar
Simple answer, yes. If you wire it with a switch as you stated it will run until you turn the switch off. Viair's site has a wiring diagram to do exactly that. That being said, the chuck you would mount at the bumper can not be the normal type you use at home that seals with nothing connected or the compressor will run and continue to build pressure until something blows. The hose kit they sell works well.
I do not run a tank but I pieced together parts to have mine run until it pressurizes then shuts off. I got a distribution block, pressure switch, pop off, gauge etc and ran ran lines to where I permanently mounted the couplers. I found everything I needed by looking around the web. There are some good diagrams on viair's site. Try jeepswag (vendor here).
Old Jul 6, 2013 | 03:29 PM
CerOf's Avatar
You did a nice job!
I'm a fan of the ARB unit. Just the single works for tired. If you turn it on, it runs until full then shuts off. It's on my short list.
Sent from some string and a few tin cans.
Old Jul 6, 2013 | 04:00 PM
slider_68's Avatar
Running a Viair 400h, wired thru a relay to a switch on the dash, Dominion Offroad bracket, and bumper mounted air coupler. It's a kit from Jeepswag that he was running as a members special on in the vendors forum
ID:	475479   Click image for larger version
ID:	475480   Click image for larger version
ID:	475482   Click image for larger version
Old Jul 6, 2013 | 06:21 PM
Thanks for the responses. With your help and a little more research, I understand the difference now. The Viair models that end in "C" are meant to be used with a tank and the models ending with an "H" actually have a cutoff switch if I've got it right. Now I'm going to have to rethink my strategy. I think by the time I collected everything I needed it would be a lot more expensive than I originally thought. I really like the idea of having the convenience of a chuck on the bumper but I may just go with the Viair 88p 45% duty cycle and says good for 33" tires. Not as convenient but around 70 bucks so I may be able to live with it.
Old Jul 6, 2013 | 08:39 PM
jadmt's Avatar
JK-Forum Ambassador
I have a viair 400P and it pumps my 33's up very fast. I'm not sure how long it will run before kicking off but I can air 4 33's from 0 to 35psi in nothing flat and it does not kick off. i kind of like that I can take it with me for other things.
