vibes with skid plate
Old Nov 10, 2008 | 05:25 AM
rocknredrubi's Avatar
Default vibes with skid plate
I have the rock hard engine/tranny skid. I get vibes around 60mph and up. No vibes without the skid plate.
1. I have moved the exhaust up so its not touching.
2. As that didnt fix the problem, I cut out 3 x 8 inch where the exhaust is closest and welded in a plate another quarter inch lower. The exhaust is nowhere near the plate at this point - cant muscle it anywhere near the plate either.
3. I have put rubber washers between the front supports and the engine mounts, between the front supports and the skid pate, and between the skid plate and cross member.
4. I have triple checked that everything is torqued down.
I am out of ideas.
Old Nov 10, 2008 | 05:36 AM
HappyCurmudgeon's Avatar
Eternal ***erator
I have zero vibrations on mine, it is installed exactly as provided. The only issues i have seen where all exhaust related.
Is anything hitting one of the drob brackets in the front?
Also, it's a pretty big flat plate and it might be reflecting a vibration noise back up that was there that you just didnt hear before?... ~just a thought.
I think someone else mentioned hearing more with it on come to think of it.
There is a thread about this somewhere, I'll lokk it up.
Edit:
Here it is: Rockhard Engine Skid = very minor vibes?
Old Nov 10, 2008 | 05:50 AM
Edit:
Nothing is close to the drop brackets.
I cant figure out what is special about 60+ mph. Thought maybe the wind was blowing something into something else. Cant find what that something is...
Thanks for the link. Thats where I got the "raise the exhaust idea".
