VIPER Throttle Body
Old Nov 27, 2010 | 10:16 AM
  #21
Ario56's Avatar
Well, I guess that solves this debate...
https://www.jk-forum.com/forums/show...viper+throttle
Old Nov 27, 2010 | 11:08 AM
  #22
JPop's Avatar
Not without a little more miles and also knowing what kind of gains can be had.
Old Nov 27, 2010 | 12:19 PM
  #23
98jeepboy's Avatar
I just have a few questions. Did you tune with the flashpaq after you installed or befor? Was it just plug and play? I ask for the sake of pure data. I interested in this for a stock tune app.
Old Nov 27, 2010 | 02:43 PM
  #24
JK GABY's Avatar
I have the throttle viper 72 mm with a Diablo sport trinity .I increase the amount of Gas and Timing and it work
Old Nov 27, 2010 | 05:27 PM
  #25
burnout88's Avatar
I have had the flashpaq installed for almost a year prior to this install. I changed nothing after the install. Did not even disconnect the battery. I just bolted it on and drove away, so yes it is plug and play. If you are going to use the stock air box and tubing then you will need an adaptor like the Spectre Cold Air Intake 4 Inch To 3 Inch Reducer Coupler. If you have a CAI then you may not need the adaptor like I did not need it.
.moparsupercenter.com/976x.htm[/url]
or
.summitracing.com/parts/SPE-9761/[/url]
Old Nov 27, 2010 | 07:10 PM
  #26
Loadbreak's Avatar
Subscribed.
Old Nov 27, 2010 | 07:33 PM
  #27
Ryan L's Avatar
Before and after dyno charts with A/F read outs?
Old Nov 28, 2010 | 03:52 AM
  #28
JPop's Avatar
That's a ton to ask for from the end user and I'd be every bit as happy with some superchips 0-60 data acquisition. In fact, I'd be happy just knowing that there aren't any CELS or DTCs after a couple tankfuls as I'm sure it will bring a modest amount of power.
Old Nov 28, 2010 | 04:00 AM
  #29
1230frstap's Avatar
Former Member
Sorry to be a buzz kill, but we all know that dealers can be real jerks...knowing that they would have to prove that this directly caused a failure to something engine-related, can anyone foresee dealerships giving hell to people who put this on? JPop, any ideas?
Also, what kind of gains did you get when you put the throttle body spacer in, mostly low-end rpm's?
Cheers!
Old Nov 28, 2010 | 04:14 AM
  #30
pentagon's Avatar
Originally Posted by burnout88
Hey guys, I just installed a Viper throttle body on my 07 JK. First observations are throttle response is definitely way up and the motor tacks up in rpm a lot faster. Cruising rpm on the highway also appears less resticted. No problems or warning lights and it bolts right up. It is almost a solid 1/2 bigger in diameter. The stock one looks really small next to the Viper one.
It is a noticeable improvement, but don't expect 20 hp out of it. Overall, I am happy with the purchase.
Mopar part # 53032837AB got mine for only $135 bucks!!!
Thanks for the information.
