want to know how to set caster
Old May 19, 2008 | 08:07 PM
cmeroln75's Avatar
Default want to know how to set caster
i am going to put on a rock krawler 3.5 x factor mid arm lift. i know i will have to set caster but i have no clue how to set it. so could someone tell me what i will need as far as tools and how to set the caster. i think i am going to have to set it +6 degrees but i am going to call rk to see their recommendation.
Old Jul 30, 2008 | 02:40 AM
Andy25's Avatar
I just put in the same kit . in there instructions they give you what lenghth to make your arms but no specs on what degree castor to use or anything.
Just a question with your lift what shocks did you get ?
on there webpage they say 28" inch extended did you go with that?
This is no good!!! your drive shaft rubs on the exhaust as it goes past the crossmember right on the cv boot too!. I got the rancho 9000xls i do not recomend them at all for this lift. get a shock you can run upside down or else you will have drammas of the shocks rubbing on the rear track bar bracket
I wish somone told me all this before i got everthing ... theres no taking it back when you live in australia
Old Jul 30, 2008 | 03:24 AM
HappyCurmudgeon's Avatar
Eternal ***erator
Specs are here:
SUSPENSION QUESTIONS
that is taken from the Sticky at the top of this forum page
'MODIFIED TECH FAQ - Answers to the Questions Every Newbie Has "
