want to lift 2.5 - 3 in best lift?
Old 01-29-2014, 01:07 PM
papajohn18's Avatar
Default want to lift 2.5 - 3 in best lift?
was looking to upgrade stock suspension for a lift but not too tall, currently running 275/65R18 tires on atx teflon. next thing is bushwhacker flat fenders. then i was looking between the AEV 2.5'' or the rock krawler max travel 2.5'' . Right now the jku is my daily driver; city and backroads and i plan on doing some offroading and i am fairly new to the jeep world, if anyone is running either of these or knows any info that'd be swell, i really want a quality lift.
Old 01-29-2014, 01:16 PM
BlackRockBurner's Avatar
Have you looked at the multiple lift threads, including the "Stickie" threads? There are 7 years of thoughts, opinions and experience of information. It really comes down to what type of trails you hit and what size tires you want along with how much you want to spend. Finding the balance is the goal.
Old 01-29-2014, 02:32 PM
okeedoky0's Avatar
BDS lifts have a lifetime warranty.
Old 01-29-2014, 03:03 PM
jkfanatic's Avatar
Metalcloak!
Old 01-29-2014, 04:31 PM
afpilot82's Avatar
I'd recommend the search function....please!
Old 01-29-2014, 04:38 PM
ShutterBug's Avatar
Rock Krawler
Old 01-29-2014, 04:44 PM
Tripletsi's Avatar
This question is asked every other day, ^ I agree in using the search function for reviews.
If you cut your fenders and add a lift be prepared to buy 35's, unless you like your tires looking like little donuts. Both AEV and especially the RK are set up for a fully modified Jeep. If yours is still stock it'll ride stiff and the RK will net you around 3.5". Anything over 3" it is recommended to install new driveshafts. Another big expense...
I'd personally pick up an EVO Protek Skid System and a full set of lower control arm skids first. A stock Jeep can handle more than you think, it helps to have some added underbody protection. Lots to learn, good luck and welcome!
Old 01-29-2014, 04:45 PM
Billbikes's Avatar
Coil overs....
Old 01-29-2014, 05:22 PM
HornetJK's Avatar
AVE lifts---be careful of all the brackets they use to to correct the geometry instead of adjustable track bars and control arms. The brackets tend to bend/brake off road. The springs are decent and comparable to Old Man Emu springs in the ride.
Rock Crawler makes great durable lifts but provide a stiffer ride higher end shocks are a must with their springs.
Don't leave out The teraflex 2.5 and I am partial to the Old Man Emu Long Travel kit that Northridge 4x4 offers. Its one of the most complete higher quality lifts for the money. It rides great handles great. Comes with adjustable track bars, front lower adjustable control arms, sway bar links, bumpers shocks and more.
Old 01-29-2014, 05:33 PM
espi's Avatar
Can you post an example if a bent/broken AEV bracket. I have the Rancho version that is much more stout. Also you can always get adjustable CA if you want. The price of AEVs 2.5 is right on par with other kits containing the same components.
FWIW if you get the AEV 2.5 pick up either a set of front swaybar discos or a set if crown rear links for the front. Also an adjustable front TB would be nice.
Quick Reply: want to lift 2.5 - 3 in best lift?
