Warn Dana 30 hub conversion?
Old Aug 31, 2007 | 09:42 AM
Blue's Avatar
Default Warn Dana 30 hub conversion?
Does anyone know if Warn will come out with conversion kit for the hp dana 30 on for the Jk?
Old Aug 31, 2007 | 09:45 AM
Northridge4x4's Avatar
Sponsoring Vendor
I Dont think warn is going to but i do Know of another company that is working on one right now. I will find out if i can let the cat out of the bag.
David
Old Aug 31, 2007 | 09:51 AM
Blue's Avatar
thanks Northridge
Old Aug 31, 2007 | 10:08 AM
IGOFSHN's Avatar
The problem they will have is getting the speed sensors to work. the attach into the hub and with a conversion the stock hub goes away.
Old Aug 31, 2007 | 10:25 AM
Blue's Avatar
I'm not familiar with the operation of these hubs but the replacement hubs would still turn, its the axles that would stop turning. I need to pull the wheels and look. It seems like the sensors would be on the rotors.
Old Aug 31, 2007 | 01:52 PM
brokebolt's Avatar
Thumbs up
I too would be very interested in a stock axle locking hub upgrade kit.
Pushing a live front axle in the rain on a short wheel base vehicle doesn't sound like much fun to me.
I would be really interested if they offered a AWD transfer case for the JK...that would be the cats meow in my book. I own two other vessels with them, 1978 Dodge Power Wagon and a 2005 Hemi Durango, both rock on slippery roads. And that is even before they are in '4 lock'.
Old Aug 31, 2007 | 02:02 PM
Renegade's Avatar
A live axle in the rain is no real problem. Wranglers have been doing this for years (can't remember when the disconnect went away on the YJ). An AWD T-case would likely reduce the already poor gas mileage. Also, due to it needing more parts, would also likely be more prone to breakage. With the JK's traction control/ESP, there is much less of a NEED for AWD.
Old Aug 31, 2007 | 02:23 PM
brokebolt's Avatar
Well that is not exactly all true, yes the ESP does aid in traction control when driving on adverse road conditions so AWD is not as much an issue of control but performance. Having driven all types (and I mean ALL) I can confidently say that the front axle in my Jeep does drag on the performance due to front axle "push".
But parts breakage and worse fuel economy simply isn't total true. Your total fuel consuption should not be effected by more than 5% with or without hubs. Anyone that has real world numbers feel free to chime in with your opinions/results.
Remember that you are already spining the entire drive train up to and including the transfer case front output shaft. The only part of the 4WD that is disengaged is the splined coupler thingy (not a techical term) that links the two ouput shafts together. You are even spining the interals of the transfer case eventhough they are not being use for propoltion. An exploided view will show this clearly if one was so inclined to research my accuracy. In fact an AWD will have less wear as you are spining the parts and peiced in the normal direction of force. When not engaged all the forward motion is applied to the reverse side of all the same parts. Thus you would have wear when not engaged, however small and unmeasureable. Unlike coasting in gear, you are turning the parts more miles not engaged in 4WD than engaged...well for the average guy I would estimate. For those true off-road guys that never disengage the 4WD (or very rarely) this discussion would not apply. These are the benefits of the locking hubs. You can disengage the parts when not in use thus saving fuel and parts wear, requardless of now minimal.
Old Aug 31, 2007 | 03:16 PM
Renegade's Avatar
Although I still don't agree with you on most of these points, I need to clarify that I would indeed actually like to have manual hubs as an option. I certainly don't understand your statement about "those true off-road guys that never disengage the 4WD." I don't know ANYONE who never disengages 4WD.
Old Aug 31, 2007 | 03:29 PM
brokebolt's Avatar
Agree or disagree...that is the great thing about these thread boards; hell america for that matter, the information can flow like water from a snow melted river.
Ask around at local Jeep rallies (find the guy with the most grime under his finger nails), talk to some local shops (the best ones are the shops with a old bath tub out back full of empty beer cans) ask the parts guy if you can get a copy of some of his books he is always looking at when you come in and ask for the most obscure part you have on your rig. One guy told me my parts page was better than his...he was the parts and service guy at the automotive dealership!!! It pays to ask questions...and listen to the answer.
True off road guys...ranch hands, farmers, trailer buggies...
For those guys above I would be more concerned about foreign material in the differential and such. Dirt is far more intrusive than a well lubed differential crusing down the highway on a sunny day, engaged or disengaged.
