Warn HS9500i Spool Direction
Old Jan 6, 2015 | 08:44 AM
Tim08JK's Avatar
Default Warn HS9500i Spool Direction
I have the Warn HS9500i winch on the front of my JK and am not sure that I have it spooled properly. Currently, the rope is coming from the top of the drum, however I'm thinking it should be from the bottom. Which way is correct?
I tried searching around for the manual, but had no luck in finding it.
Thanks for the help!
Old Jan 6, 2015 | 09:33 PM
JTB488's Avatar
Spool in from the bottom.
Old Jan 6, 2015 | 09:43 PM
ronjenx's Avatar
If the center line of the drum is higher than the fairlead, the cable comes from the bottom of the drum.
If the center line of the drum is lower than the fairlead, the cable comes from the top of the drum.
Old Jan 8, 2015 | 03:54 AM
castlerockjeep's Avatar
My dads is from the bottom.
Old Jan 8, 2015 | 05:19 AM
ade's Avatar
ade
Originally Posted by Tim08JK
I have the Warn HS9500i winch on the front of my JK and am not sure that I have it spooled properly. Currently, the rope is coming from the top of the drum, however I'm thinking it should be from the bottom. Which way is correct? I tried searching around for the manual, but had no luck in finding it. Thanks for the help!
Post a picture of how you have it setup.
Old Jan 8, 2015 | 06:50 AM
Invest2m4's Avatar
Agree with this, post a pic. Unless the winch is mounted backwards, you can't spool from the top (unless on the controller forward is actually what pulls it in, which is very wrong).
Old Jan 8, 2015 | 10:29 AM
Tim08JK's Avatar
Ok, I'll grab a picture when I get home and post it up.
Old Jan 8, 2015 | 11:31 AM
ronjenx's Avatar
Just look at the drum, and see if the top or the bottom is more in line with the fairlead.
Old Jan 8, 2015 | 01:21 PM
nthinuf's Avatar
15 years and still going strong, but I really need to get around to yanking this thing and cleaning it up...
The parts diagram is on their website. I still have the paper copy of the manual, but haven't seen it online.
http://www.warn.com/truck/Replacemen...srrpl37-38.pdf
Old Jan 8, 2015 | 03:11 PM
Tim08JK's Avatar
The winch was handed down to me and its still going strong! Here are a couple of pictures...
ID:	591132   Click image for larger version
