Warn Powerplant help
Old Oct 11, 2007 | 09:42 PM
CLACKEY(_!_)'s Avatar
Default Warn Powerplant help!!!!!!!someone helpppppppp
Powerplant installed and all hooked up. Positive line is hooked to positive terminal on battery. Negative line is hooked to negative terminal on battery. 10 amp fuse is good. Nothing works on the Powerplant. No air and no winchy winchy. Any thoughts?????
Old Oct 11, 2007 | 09:51 PM
Sporticon's Avatar
Are the positive and negative lines hooked up at the powerplant
Old Oct 11, 2007 | 09:57 PM
Yes, they came hooked up out of the box. I didn't double check them.............yet. But I'm pretty sure thay are hooked up.
Old Oct 11, 2007 | 10:00 PM
Sporticon's Avatar
pretty sure!!!
Sounds Like it needs to be double checked, make sure no rubber spacers for shipping on there
Old Oct 11, 2007 | 10:05 PM
pretty sure!!!
I hope it's that easy.
Old Oct 12, 2007 | 04:17 AM
Robar's Avatar
Originally Posted by toad
TMI
Old Oct 12, 2007 | 05:21 AM
wayoflife's Avatar
JK-Forum Founder
Are you sure that you have the winch/air selector switch set to the correct setting when you try to turn either on?
Old Oct 12, 2007 | 06:00 AM
I moved them every which way. Nothing
Old Oct 12, 2007 | 06:23 AM
tgrt's Avatar
Former Vendor
You didn't say anything about the intake being installed not that it should matter. But, I remember the instructions to do that weren't exactly in line with the rest (thank goodness that you can remove the shielding).
Make sure that the remote is plugged in well, make sure your selector switch is all the way in position, and make sure the clutch switch is not in freespool.
Old Oct 12, 2007 | 06:24 AM
Originally Posted by SDMF
So you saw my post last night and then ran out to the garage to install it huh.
I put it on Wed. night but had issues that needed to be addressed. Last night I took it to Aarons house and took it all apart and put it back together. Tonight I'll be at your house trying to figure out why it doesn't work!!!!!
