Warn Zeon 10s
Gonna be pulling the trigger soon on one of these winches! It's going on a Brawler lite front bumper. I know I need the spacer plates, but do I have to buy the winch plate on top of the 1200 winch? Thanks!
If you are referring to the Hawse fairlead mount as the winch plate then yes you will need to purchase that as well.
I just bought a brawler lite, and yes, you need to buy the warn Zeon adapter plate that poison spyder sells that allows the zeon to fit to that bumper. It's not something that warn sells, you need to get it from PSC or a retailer.
Yes, you will need one of these as well. PSC sells them for $50'ish, but you can versions to mount your license plates, after market lights, etc. depends on what you want.
just a word of advice when installing the winch line use a metal coat hanger and not the supplied zip tie.
You will understand when you read the directions. The zip tie will break right away.
Sent from my ADR6425LVW using Tapatalk
