Warning on Budget Boost and Sway Bar..
Old Jun 11, 2007 | 07:05 AM
Snatchpeterman's Avatar
If using the budget boost is going to cost much more than a couple hundred bucks then I will just wait and get the Ultimate kit. What do those Skyjacker parts cost? So there is no "out of the box" Terra Flex Budget Boost that will work on the Rubicon? Please confirm this so I can cancel my order today. The kit with the brackets won't work?
Old Jun 11, 2007 | 07:51 AM
Woods's Avatar
JeepSWAG
Sponsoring Manufacturer
Originally Posted by 1BADJK
Those running a Tera Flex or other Budget Boost please be aware that if you disconnect the Electric sway bar and do any wheeling your sway bar links will fully extend when flexing and then fold back the wrong way towards your tie rods creating damage.. Instead of folding back up towards the frame they will fold down towards the tie rods... Had this happen today... Not fun.. I hope this makes sense to others.. J
Hey BadJK,
Are you running the shock extenders? Stock shocks? Stock shocks without extenders, may be enough to prevent over-extension of the sway bar??? I'll try to put my JK up on a jack this afternoon.
Thanks for the note on this.
Old Jun 11, 2007 | 07:58 AM
duffman's Avatar
I guess I've been lucky but my rubicon with TF BB has had no problems with this so far and I've had my suspension maxed out quite a bit. Maybe its time to get the skyjacker rear links and put the stock rears in the front just for the peace of mind. Its only $50...
Old Jun 11, 2007 | 08:11 AM
1BADJK's Avatar
Originally Posted by Woods
Hey BadJK,
I am running shock extenders.. I will be extending my links this week and make sure this fixes the problem..
Old Jun 11, 2007 | 08:25 AM
wayoflife's Avatar
JK-Forum Founder
Wow, in all honesty, this is the first time I've heard of this problem. Certainly, I never experienced it when I had this lift on my JK (and I wheeled it hard) but in all fairness, keeping the short links was always a concern of mine. In the end, if you have a Rubicon and intend to keep this lift on for the long haul, I think longer front links are definitely the way to go.
EDIT: Hey 1BADJK, just out of curiosity, are you running new/longer shocks with this lift or are you running the shock extenders that came with the kit?
Old Jun 11, 2007 | 09:31 AM
Sixgunz's Avatar
I posted this problem back on May 5th. I noticed it immediately when I put the BB on & dropped the front end down off of the jack, they flexed/folded the wrong direction immediately.
Here's the link to my 1st post...
https://www.jk-forum.com/forums/show...light=teraflex
Old Jun 11, 2007 | 10:10 AM
tgrt's Avatar
Former Vendor
Does anyone have a picture that shows what is happening?
Old Jun 11, 2007 | 10:18 AM
07JKX's Avatar
good thing i dont have that feature
j/k... sorry to hear about the damage!
Old Jun 11, 2007 | 10:31 AM
wayoflife's Avatar
JK-Forum Founder
Right, but did you have your shocks installed at the time and if you did, are you running new/longer shocks or are you using shock extensions?
Old Jun 11, 2007 | 11:09 AM
Sixgunz's Avatar
I have the Teraflex shock extensions with the stock Rubi shocks, all put on at the time of the lift install.
