weird idle
A few common fixes that are worth doing anyways are, clean the throttle body, run some seafoam through the brake booster line, and make sure your battery is in good condition, have clean tight connections and add an additional ground wire from your negative terminal to the alternator bracket. One of those things should fix your random idle issues.
Been having this same problem too. Happens randomly. Been to the dealership 3x and they cant fix it because "nothing is wrong". I had the throttle body cleaned and it still happened two days later. Guess I'll have to check the plug wires but if anyone has more info I'd like to know too!
