weird idle
Old Jul 20, 2012 | 03:05 AM
the_cuse420's Avatar
Default weird idle
When im setting at a stop light or a stop sign, the idle will drop to 400rpm and then jump to the normal idle. Anybody have problem, and if so how did u fix it.
Old Jul 20, 2012 | 03:57 AM
efan450's Avatar
A few common fixes that are worth doing anyways are, clean the throttle body, run some seafoam through the brake booster line, and make sure your battery is in good condition, have clean tight connections and add an additional ground wire from your negative terminal to the alternator bracket. One of those things should fix your random idle issues.
Old Jul 20, 2012 | 04:05 AM
ZMagic97's Avatar
I agree, check the throttle body first as well as the air filter.
Old Jul 20, 2012 | 04:34 AM
n3tfury's Avatar
One guy swore that changing his gas cap to a locking one fixed his weird idle issue.
Old Jul 20, 2012 | 05:29 AM
Ryan0260's Avatar
Agree. Try these things first and see if they fix it. Many times it is something simple
Old Jul 20, 2012 | 05:35 AM
Vincent's Avatar
My wife's JKU had the same issue turned out to be a bad plug wire.
Old Jul 20, 2012 | 10:15 AM
Cool thanks for the info
Old Jul 20, 2012 | 10:53 AM
JK_KB's Avatar
Been having this same problem too. Happens randomly. Been to the dealership 3x and they cant fix it because "nothing is wrong". I had the throttle body cleaned and it still happened two days later. Guess I'll have to check the plug wires but if anyone has more info I'd like to know too!
Old Sep 26, 2012 | 06:49 AM
JBonk10's Avatar
It could be the PCV. It can get stuck open.
Old Sep 26, 2012 | 08:55 AM
AJB's Avatar
AJB
I have the same problem. It only occurs if I start it and leave it in park for a little bit. Never yet at a red light.
