Weird warning light behavior
Old May 14, 2013 | 12:37 PM
  #21
ECE00jk's Avatar
Originally Posted by jkmadness
Clock spring....?
Clock spring is the wiring harness in the steering wheel has to do with steering angle sensor if it thinks your wheels are one way and the streeing wheel is the other way it controls you abs along with air bags and horn steering wheel controls....thats why the dash lights up when it has issues!
Old May 22, 2013 | 04:03 AM
  #22
jkmadness's Avatar
It happened again today,I hope the dealer doesn't look at me crosseye when i tell them this is what i think it is,there's a lot of people out there with this problem they should recall it
Old May 22, 2013 | 06:04 PM
  #23
Boilermaker52's Avatar
Default Weird warning light behavior
Dude! Same thing, '12 Rubicon, same indications at varying speeds. It's at the dealer now. I'm forwarding this thread (and the video!).
Old May 23, 2013 | 01:23 PM
  #24
mcseanny's Avatar
I had this happen to my '07. It turned out to be the chassis ground wire in the engine compartment was loose. I tightened it down and the issue hasn't returned.
Old May 23, 2013 | 01:29 PM
  #25
jkmadness's Avatar
Where exactly because there's a lot of ground conections on the fenders all around and one on the engine block
Old May 23, 2013 | 06:29 PM
  #26
jkmadness's Avatar
Please let me know how you made out
Old May 23, 2013 | 06:42 PM
  #27
scooby snacks's Avatar
Still a problem for me... going for oil change on Saturday so I'll have them look at it again.
Old May 23, 2013 | 07:17 PM
  #28
ilikeguns's Avatar
subscribed
Old May 23, 2013 | 08:20 PM
  #29
Dealer claims to have solved it. Says the motor for the swaybar is receiving an incorrect (zero) speed input from the transmission, causing the warning. They're getting a new one shipped in and installed tomorrow (swaybar motor). I'll get more specifics when I get it back and will post an update.
Old May 24, 2013 | 01:54 AM
  #30
jkmadness's Avatar
I hate to be the bubble buster but. I have a sport they don't have electric sway bar discos, i would point that out to the dealer since we have the same problem
