welding your Cs.
Old May 24, 2012 | 07:13 PM
jaybrown's Avatar
Default welding your Cs.
went to a local shop and they said if you weld your Cs it just put pressure on the shaft and that breaks. What's the best thing to do ?
Old May 24, 2012 | 07:20 PM
No1AP's Avatar
That doesn't make any sense. I wouldn't talk to that guy any more. Unless he meant axle tubes maybe?
Old May 24, 2012 | 07:27 PM
FoxRacingJMC's Avatar
X2 on that, i'm pretty sure he meant the axle tube....still makes no sense though because the added pressure still gets distributed throughout the gusset itself which is an added steel.....gusset - meant to strengthen weak points with pressure related issues. If that makes any more sense to you...
Old May 24, 2012 | 07:29 PM
scooby snacks's Avatar
Never heard that one... better get a second opinion from a real welder!!
Old May 24, 2012 | 07:40 PM
Serg5000's Avatar
I did mine this past week.
ID:	321198   Click image for larger version
Old May 24, 2012 | 07:41 PM
Serg5000's Avatar
Just do it.
ID:	321201   Click image for larger version
Old May 24, 2012 | 08:58 PM
Sahara_Maverick's Avatar
The C is likely a forged steel part. When you weld it, the temperature changes the steel grains and the final product might end-up worse than the non-reinforced original. So, if you plan to do it make sure that the guy welding it really knows his stuff.
Old May 24, 2012 | 09:34 PM
rb1boxer_3's Avatar
Awesome what kind of paint did you use. I just ordered gussets today from Evo.
Old May 24, 2012 | 10:01 PM
Tonka_yellow's Avatar
Someone can lay some nice beads. I will be doing mine here in a few weeks.
Old May 25, 2012 | 02:26 AM
DadsCJ's Avatar
Mine is being done now.....
