What is this???
Old Mar 12, 2011 | 09:18 AM
Rexlba's Avatar
Default What is this???
What is this and can I just grind it down or cut it off? Will it puncture my tires??
Old Mar 12, 2011 | 09:20 AM
Rexlba's Avatar
Another pic
wayoflife's Avatar
JK-Forum Founder
that's your pinch seam and yes, you can cut and or grind it down. in fact, when running bigger tires, you need to.
Old Mar 12, 2011 | 09:23 AM
Rexlba's Avatar
Any special precautions I need to know before I start working in it??
Old Mar 12, 2011 | 09:25 AM
wayoflife's Avatar
JK-Forum Founder
no, not really. it's easier to do with your tires off and a sawzall will take care of this in seconds but, i have done it on the trail with my tires on and a hacksaw in about 5 min a side.
Old Mar 12, 2011 | 09:26 AM
EarlyJk's Avatar
Take your tire off before you do it. Also if you didnt know what that was in the first place maybe you should let someone else grind it down. Not hating, just saying.
interceptor_1972's Avatar
If you cut it, make sure to spray it with some rust proofing or bedliner spray. Some people use a BFH and just pound it out of the way - a cut looks cleaner.
Old Mar 12, 2011 | 09:28 AM
GreenJK07's Avatar
Yup! Or you can bend it over with a hammer.
Old Mar 12, 2011 | 09:33 AM
Rexlba's Avatar
Thanks For the info guys!!!
Old Mar 12, 2011 | 09:39 AM
sringer's Avatar
Pinch seam. People running 37's and larger usually trim it
