What About G2?
hey i was going to buy alloy usa gears or superior...... ive heard both are great.
but searching on the web ive seen G2 and they have also a very nice diff cover, does anyone uses this gears and diff cover? what do you think about that brand?
thanks
thanks
https://www.jk-forum.com/forums/sponsoring-manufacturers-vendors-check-out-cyber-monday-specials-24/g2-gears-install-kits-smoking-deals-92891/
Check out this thread from the vendor page. This is a great deal as well as a warranty on the Gears.
I just had 5.13 G2 gears installed in my unlimited. Not a sound coming from them. Everything is running smooth. I only have a 1000 miles on them so far, but ill let anyone know if anything happens. So far i recommend them!
I had G-2 4.88s installed in June. Haven't had any issues from them, and the aluminum diff covers I went with because I like the look.
Will let you know if I have any issues with either.
G2 seems like a fresh company based on their website with 4wd being their only dealer
I was told that Yukon makes them
David
IMO gears are not an area that you should skimp on. Most of us do not have the ability (or at least lack he tools) to regear at home. Keeping that in mind, I refuse to skimp when buying gears, because labor is so expensive. I would rather get the best gears I can up front and not have to worry about them holding up. I think superior makes great gears and that is what I am running. But if you are on a tighter budget, why don't you get the yukon deal from northridge4x4.
he has a deal on yukon gears with install kits for only $399.95! Why not get that deal and just add the bearings that you need if your axles are low mileage. I had under 15k miles when I regeared, so I just replaced the pinion bearings (about $30 at oreileys) and got my superiors with install kits from david for 599. But you could do the same with yukon gears for 399 now. I would do that over g2s myself. David also has customer service second to none.
http://www.northridge4x4.com/proddet...INSTALL&cat=36
