What About G2?
Old Jul 17, 2009 | 09:07 PM
tento0929's Avatar
Default What About G2?
hey i was going to buy alloy usa gears or superior...... ive heard both are great.
but searching on the web ive seen G2 and they have also a very nice diff cover, does anyone uses this gears and diff cover? what do you think about that brand?
thanks
Old Jul 17, 2009 | 09:16 PM
DAMN JK's Avatar
https://www.jk-forum.com/forums/sponsoring-manufacturers-vendors-check-out-cyber-monday-specials-24/g2-gears-install-kits-smoking-deals-92891/
Check out this thread from the vendor page. This is a great deal as well as a warranty on the Gears.
Old Jul 17, 2009 | 11:07 PM
lv jk's Avatar
***erator
I just started hearing about this brand, but all of a sudden I am seeing it everywhere. Look nice and the link above has some good info. Keep us updated if you go this route.
Old Jul 17, 2009 | 11:26 PM
ckmehl's Avatar
Default I'm
i'm planing on going this route unless i can find a good deal on superior gears. other wise it G2 all the way.
Old Jul 20, 2009 | 10:20 AM
tento0929's Avatar
hey is there quality issues on gear brands????? are superior better because there more exxpensive??? or alloy usa???
Old Jul 20, 2009 | 10:31 AM
shadowrwr's Avatar
I just had 5.13 G2 gears installed in my unlimited. Not a sound coming from them. Everything is running smooth. I only have a 1000 miles on them so far, but ill let anyone know if anything happens. So far i recommend them!
Old Jul 20, 2009 | 11:11 AM
Jmacaws's Avatar
I was told that Yukon makes them
Old Jul 20, 2009 | 11:38 AM
cheflee's Avatar
I had G-2 4.88s installed in June. Haven't had any issues from them, and the aluminum diff covers I went with because I like the look.
Will let you know if I have any issues with either.
Old Jul 20, 2009 | 11:43 AM
Northridge4x4's Avatar
Sponsoring Vendor
G2 seems like a fresh company based on their website with 4wd being their only dealer
G2 is owned by 4 wheel parts , 4 wheel drive hardware.
No Randys ring and pinion does not make G2.
David
Old Jul 20, 2009 | 11:46 AM
bigbluejk's Avatar
IMO gears are not an area that you should skimp on. Most of us do not have the ability (or at least lack he tools) to regear at home. Keeping that in mind, I refuse to skimp when buying gears, because labor is so expensive. I would rather get the best gears I can up front and not have to worry about them holding up. I think superior makes great gears and that is what I am running. But if you are on a tighter budget, why don't you get the yukon deal from northridge4x4.
he has a deal on yukon gears with install kits for only $399.95! Why not get that deal and just add the bearings that you need if your axles are low mileage. I had under 15k miles when I regeared, so I just replaced the pinion bearings (about $30 at oreileys) and got my superiors with install kits from david for 599. But you could do the same with yukon gears for 399 now. I would do that over g2s myself. David also has customer service second to none.
http://www.northridge4x4.com/proddet...INSTALL&cat=36
