what am I missing?
Old Jul 23, 2013 | 09:53 AM
Captain Obvious's Avatar
Default what am I missing?
I'm gathering parts to lift my '12 jkur and want to make sure I've got everything I need so I don't get stuck halfway into the job realize I missed a part. Just limiting to actual NEEDED parts (not stuff like truss, etc, I'm planning on that stuff at a later time, just wheel easier till then)
what I've got so far:
Skyjacker 4" lift
37" goodyear mts
17x8.5 MB Wheels Razor
4.56 gears
Old Jul 23, 2013 | 09:58 AM
forgot to add, programer is on the way to correct for gears and tires.
Old Jul 23, 2013 | 10:12 AM
Sgt Mack's Avatar
Does the lift kit have adjustable track bars or at least track bar brackets? I'd recommend using the rear bracket that has a saddle bold that goes around the axle. I had a skyjacker years ago with just a bolt on bracket that snapped on the highway.
Other things to ensure would be brakeline extension brackets, and depending if your a 2 or 4 door, clearance issues with your front drive shaft and your exhaust cross over.
You shouldn't have any issues clearing the tires, but your back spacing should be at about 3.5-4.5. You might rub if you disconnect your sway bars.
Old Jul 23, 2013 | 10:17 AM
Riznoy's Avatar
Probably going to need a 1310 driveshaft, and might want to invest in skid plates and sliders if
you're going to wheel.
Old Jul 23, 2013 | 10:18 AM
mattgt5's Avatar
Also need bump stops and shocks, not sure what comes with that kit. If you don't do a new front drive shaft you will need some sort of exhaust spacer for the cross over. At 4" you will want at least front lower control arms, preferably all 8 for drivability.
Old Jul 23, 2013 | 10:19 AM
mattgt5's Avatar
Trim pinch seam in rear with 37", not sure you can trim it enough without rear arms to slide the axle back.
Old Jul 23, 2013 | 02:51 PM
kjeeper10's Avatar
Vet Army
Stuffed with 35's Click image for larger version
What else is included with that kit? 4" is opening a can of worms if not done correctly.
Old Jul 23, 2013 | 03:09 PM
RND's Avatar
RND
Don't forget new seat covers and husky.liners. You'll need those with that tall of a lift.
Old Jul 23, 2013 | 03:17 PM
1995nscajeep's Avatar
You might want to sleeve and gusset the axels if your wheeling alot
Old Jul 23, 2013 | 04:00 PM
RoysRig's Avatar
Do you have a tire carrier that can hold a 37" tire?
