what to do for 35's
Hi I wanted to upgrade to 35s in a couple months what should I or what do i have to get order to do it and do it right i know i have to lift it but is there anything besides that?
Thanks Rodney
Thanks Rodney
Depending on how wide of tires you go you may need spacers or different wheels for proper backspacing. The link can answer your tire questions.
https://www.jk-forum.com/forums/modified-jk-tech-2/modified-tech-faq-answers-questions-every-newbie-has-18617/
You can even get by w/o lifting (I think) if you like tube fenders and want to go that route.
Still will probably need new wheels w/ less BS or spacers on the stock wheels.
I love my 3" Fabtech lift
Its very simple and clears 35" tires,comes with almost everything you might need,I figure soon I will need adjustable track bars for the front and back its the only thing its missing
A little expensive,but I only do a little off-road mostly the road,but has worked out just great
http://www.quadratec.com/products/16119_050.htm
POSER
POSER
Plan on buying a rear u-joint driveshaft as well. You wont need it right away. But you'll need one.
I have the same set up (3" Fulltraction ultimate kit) with 5.13 gears. Its awesome!
