what to do for 35's
Old Oct 4, 2008 | 01:10 AM
rodney's Avatar
Question what to do for 35's
Hi I wanted to upgrade to 35s in a couple months what should I or what do i have to get order to do it and do it right i know i have to lift it but is there anything besides that?
Thanks Rodney
Old Oct 4, 2008 | 02:28 AM
sn4cktime's Avatar
Depending on how wide of tires you go you may need spacers or different wheels for proper backspacing. The link can answer your tire questions.
https://www.jk-forum.com/forums/modified-jk-tech-2/modified-tech-faq-answers-questions-every-newbie-has-18617/
Old Oct 4, 2008 | 02:29 AM
jeeperjkj's Avatar
You can even get by w/o lifting (I think) if you like tube fenders and want to go that route.
Still will probably need new wheels w/ less BS or spacers on the stock wheels.
Old Oct 4, 2008 | 02:34 AM
Piginajeep's Avatar
4 door or two door? standard or auto. it makes a difference
thats a great link too!
Old Oct 4, 2008 | 02:43 AM
MrLuminosity's Avatar
I just did this .... and it is awesome... but you gotta increase to at least 4.88 gears with 35" tires to keep it from running like a slug...
Old Oct 4, 2008 | 08:57 AM
rodney's Avatar
i dont really know much about gearing how much would this cost me?
its a 2dr 5speed
Old Oct 4, 2008 | 09:35 AM
2drREDROCK's Avatar
I love my 3" Fabtech lift
Its very simple and clears 35" tires,comes with almost everything you might need,I figure soon I will need adjustable track bars for the front and back its the only thing its missing
A little expensive,but I only do a little off-road mostly the road,but has worked out just great
http://www.quadratec.com/products/16119_050.htm
POSER
Old Oct 4, 2008 | 12:37 PM
Piginajeep's Avatar
its a 2dr 5speed
you need a 3" lift with adjustable control arms so you can adjust your rear pinion.
Plan on buying a rear u-joint driveshaft as well. You wont need it right away. But you'll need one.
I have the same set up (3" Fulltraction ultimate kit) with 5.13 gears. Its awesome!
Old Oct 4, 2008 | 02:43 PM
rodney's Avatar
wow lots of money maybe ill just go with 33's since it is my daily driver. what would i need to do for that anything with gears or drive shafts?
Old Oct 4, 2008 | 02:45 PM
Piginajeep's Avatar
nope, just throw a 2" BB (spacers and new shocks) boast on, and you'll be good!
