what do the experts see
Old Nov 29, 2009 | 02:18 PM
mkjeep's Avatar
Originally Posted by hdrider
It is a little flighty going down the highway (proper correction for this ??)
Longer links where put up front (will the JKS adj disconnects take care of this?)
I do have the Crown extended brake lines on order
Correct on shocks. I have 1 inch of up travel left. But OME long travel shocks are on order. That should fix that (yes?)
You'll be good with the long travel shocks.
Old Nov 29, 2009 | 05:00 PM
river2c's Avatar
You definitely need extended bump stops front and rear, especially with the long travel shocks. With the OME lift and the spacers on top, you probably have close to 5" lift. I would keep a close eye on the drive shafts.
Old Nov 29, 2009 | 05:49 PM
DtownJK's Avatar
Steering stabilizer looks like it's backwards.
Check out WOL write up on replacing the stock one. Piston end should mount to the tie rod not the shaft end. Even after market stabilizers have it mounted with the piston end on the tie rod.
http://project-jk.com/jeep-jk-write-...ation-write-up
Old Nov 29, 2009 | 06:02 PM
hdrider's Avatar
COPY,,, on the extended bump stops. Sooo, 3" maybe 4"?
Old Nov 30, 2009 | 05:06 PM
hdrider's Avatar
Thanks for the help,,, the items in my NEXT line should all be here and installed this weekend,,, I hope.
Probably won't leave much time to play though.
Old Nov 30, 2009 | 05:13 PM
river2c's Avatar
Generally speaking you should extend the bump stops by the same amount of the lift increase. You can get by with less but you might have some fender rubbing. The stock JKs have approximately 2-4 inches from the bottom of the bump stop to the top of the axle perch.
Old Nov 30, 2009 | 05:19 PM
spinlock's Avatar
x2 on the drive shaft. The angle looks pretty sever in the that last picture. Inspect it and maintain regularly, very regularly.
Old Nov 30, 2009 | 05:54 PM
Piginajeep's Avatar
that is not going to do him any good inspecting it.
its going to blow apart. You better get adjustable control arms to fix your pinion.
Old Dec 1, 2009 | 04:27 AM
hdrider's Avatar
Adjustable rear uppers and front lowers go on Friday.
Old Dec 1, 2009 | 06:08 AM
RyanBlack321's Avatar
Default s
so much knowledge... Great forum
