what do the experts see
That rear track bar angle also struck me as a litte steep. It'll run fine as is but in theory, you want that as level as possible to keep your rear end from wagging as much, especially at high speeds. I noticed that when I got mine leveled out with the appropriate bracketry, it really helped when hitting small bumps at highway speeds. I ended up using an axle mounted bracket(I used an RE bracket that didnt come with their original kit, mopar has a similar one, it actually attaches further out along the shock mount) as oppsed to a frame drop down bracket. Of course that will also change the length of the trackbar as well. With that bracket you will also eliminate the problem some people have had with shearing off that stock axle track bar mount.
I did a search on that muffler bearing thing and found that if it is over tightened I run the possibility of built up preasure in my tail light housing that could cause a minor explosion.
So I think I will just run it loose,,, I can barely hear the rattle if I turn my radio off.
And my butt meter and has been checked againt my GPS and is right on
But thanks for the suggestions just the same
OHHHH MAN !!!! Got everything installed today and WHAT A DIFFERANCE !!
I'm not sure what made the biggest differance but it drives like a dream and rides VERY nice. No more darting at highway speeds. And the drive shafts are at a MUCH better angle.
I without a doubt had to much lift going on with the standard OME shock (which are now for sale by the way) but the LT made a big change.
And thanks to everyones suggestions the combination of rear upper and front lower control arms made a huge change in the feel of my jeep.
I have to take it out and feel the differance with the disconnects but I'm looking forward to that for sure.
And the crown brake lines are top shelf.
Tomorrow I will do the flashpaq.
