what do higher and lower gears do?
Old Apr 8, 2009 | 08:34 PM
BlackNorthernJK's Avatar
Originally Posted by RedneckJeep
If you go from 3.73s to say 5.13s, it doesn't add ANY power. This is a common misconception. Think of it as adding a long breaker bar to a socket to break loose a stubborn bolt. Deeper gears just give you more leverage WITH the same power.
Perfect, that is the way I've been trying to explain it.
Redneck's got it.
That's why I say it will make it 'easier' to turn them tires, your not gaining power, it just feels like you've regained lost performance if you will.
-(redneck I did gain some lost mpg with my gear change as well, you were right)
ArrowheadRay, that chart is really a generalized point of view on 'performance' you may expect with the gear and tire selections. If you google other charts you'll find varying opinions and views...it is meant to provide you with an idea really.
I personally have no experience with the automatic JK's, however reading the many posts from those that do, I find that most automatics tend to need a little higher gearing (numerically) than our 6-speeds. Example, most guys running 35" tires with automatics find that 5.13's are the right gear ratio to match their requirements in overall performance and mileage...whereas their brothers running the 6-speeds with 35" tires find 4.88's are the more adequate choice...obviously their will be varying opinions on both sides as everyone has different expectations, however the majority tend to find they need to gear a little higher (numerically) with the Autos as opposed to the Standards.....with that said, will you be happy with your overall performance with 3.73's and 33" tires? I doubt it. Though you may find that you 'fit' in the top end of the "Best Gas Mileage" bracket, you may find that you'll lose the use of your Overdrive more frequently than you like, and your mileage may actually suffer, especially around town driving where your constantly stopping and going...conversely if your a long range commuter you may find your mileage improves slightly....it's all about the balance.
SO...with that said...just my opinion, but I bet you would find 4.56's or even 4.10's more suiting to your automatic with 33's. 4.10's more so if your a long range commuter with long highway stretches and your looking for absolute best mileage...or 4.56's if your like me, drives alot in town, sometimes highway, sometimes trail. Again, opinions will vary...just some food for thought.
You'll really know when you put the taller tires on with your current setup and drive around.
Old Apr 8, 2009 | 08:41 PM
just caught this post as I finished my last....have a peak
https://www.jk-forum.com/forums/modified-jk-tech-2/how-i-chose-my-gears-80975/
Old Apr 8, 2009 | 09:24 PM
ronjenx's Avatar
Originally Posted by ronjenx
Another way to look at it:
V6
6 speed in 5th (1:1)
Rear axle = 2:1
You get 6 power strokes per tire revolution.
Change the rear axle to 4:1, you get 12 power strokes per tire revolution, which feels like a bigger engine. You would go up the hill slower, but you could haul a larger load up that hill.
Yeah, it doesn't ADD power. It allows the engine to put out more of its available horse power.
An engine turning 2200 rpm can make more hp than the same engine turning 1100 rpm.
Old Apr 8, 2009 | 10:07 PM
VAMP1RE's Avatar
Originally Posted by 09rubicon
You used the R variable twice!!!!!!
Thats a great formula, hope you dont mind but I am going to copy it down and hold onto it.
haha, I noticed that too. not a bad formula at all.
Old Apr 9, 2009 | 01:56 AM
RedneckJeep's Avatar
Did you ??? Man that's GREAT! I'm not right as much as I'm wrong....but every now and then I slip up. LMAO. That's great news. So I take it your gear install went well? You might think about being an installer in your area. You could make some extra cash and some new friends pretty fast I bet. Guys that can CORRECTLY install gears are few and far between. I never have figured out why, because it's really quite straight forward.
Old Apr 9, 2009 | 04:18 AM
JPop's Avatar
Yep one of the guys at the local shop is hardly ever there any more as he does the gears for a lot of drag cars and is a source for a couple other venues. More than half his income now comes from doing gears and it all started out by just helping a few friends from the track. He said there isn't really anything hard about it but you just need to be wired so have the patience to do it right.
Old Apr 9, 2009 | 12:39 PM
wvextremist's Avatar
Fixed, sorry I did that late at night with an Iphone lucky its in english really
Old Apr 9, 2009 | 01:57 PM
VAMP1RE's Avatar
Haha, It makes a lot more since now.
