what does a superchip do?
Old Apr 7, 2011 | 07:30 AM
skidad3's Avatar
Default what does a superchip do?
I keep seeing thread about superchips. What does a superchip do for the Jeep and is it worth it?
Old Apr 7, 2011 | 08:19 AM
Goofas7070's Avatar
It made my engine sound like a 1976 Mercury Monarch. No, it was not worth it for me and I sent it back.
Old Apr 7, 2011 | 08:27 AM
nthinuf's Avatar
Did you actually read any of those threads? Or go out to Superchips website?
It has a lot of programming functions, including recalibrating for bigger tires and different gear ratios, and also allows you to change the tuning.
The majority of people have favorable reviews on it.
Old Apr 7, 2011 | 08:35 AM
shockwaveaz's Avatar
Makes it drive like a hummer
Sent from my PC36100 using Tapatalk
Old Apr 7, 2011 | 08:54 AM
TURTLECON's Avatar
Gives you options to alter the computer, such as turn off the TPMS light if you've removed the sensors, correct the speedometer for new larger tires, etc.
Old Apr 7, 2011 | 09:14 AM
MotiCross's Avatar
For me it just game more power... i actually left a message for superchips becasue i programmed it for my 33's but the speed is still off... very wierd and very annoying(anyone else experianced this problem btw?).
BUT the power it added is definitely noticable.
Old Apr 7, 2011 | 09:46 AM
nthinuf's Avatar
Known issue. There was even a post on the forums on superchips website saying that the ProCal is much more accurate with speedo recalibration, and with the flashpaq, you have to experiment with the tire size until you find the 'incorrect' size that will get the speedo correct. Their answer? Let us know what you find out...
So yeah, play with the tire size until you get your speedo to read correct.
Old Apr 7, 2011 | 09:51 AM
MotiCross's Avatar
Thanks for letting me know, i looked for it in the forums and couldnt find anything but i will let you know once i hear from them.
I have the speedo on my phone and thats how i found out at the first place, i will try to mess around and set it to the "incorrect" size and hope for good... lol
Thanks again.
Old Apr 7, 2011 | 11:00 AM
TheKid25's Avatar
Thanks again.
I didn't recalibrate my speedo when I went to 33s and mine is pretty close to right on. Just curious, did you put your tire size as 33 inches or did you actually measure your tire height and put that in?
Old Apr 7, 2011 | 11:12 AM
Monte417's Avatar
I am by no means savy when it comes to performance but not only are the speedo, gear ratio and tpms adjustments great but I gotta say that tow tune kicks ass. Im running 35s and use that tune with my stock 4:10s and have no desire to regear. My gas mileage has improved as well. An excelent piece of equipment. DO IT
