What else do I need for aev 2.5 lift
Old Jan 5, 2020 | 09:50 AM
Stuffmax's Avatar
Default What else do I need for aev 2.5 lift
I’m going to be installing next week. I ordered the geometry correction brackets but was wondering if I need anything else like a front track bar or other items? Jeep will end up with either 33s or 35s.
thanks!
Old Jan 5, 2020 | 10:52 AM
jadmt's Avatar
JK-Forum Ambassador
thanks!
You will have everything altho you might want to pick up a set of stock oem rear swaybar links to replace the brackets AEV supplies as they are kind of cheesy. The other option is if you don't have a rubicon is to add some JKS adjustable disconnects up front and if you have a rubicon get some JKS adjustable rear swaybar links and use your rears up front.
Old Jan 5, 2020 | 12:14 PM
nthinuf's Avatar
The front axle will be offset a bit to one side, but just wait until it's lifted and you get a chance to drive for a while to see if you even notice it. If 'knowing' it's minimally offset bugs you, add the trackbar and perfectly center the axle. If not, don't worry about it.
Old Jan 5, 2020 | 12:34 PM
Stuffmax's Avatar
I hate saying it but it bothers me knowing it’s off center. Lol. From what I’ve read teraflex trac bar is a popular choice but expensive . This is not a hard core Jeep. Doesn’t need anything too high end. What should I go with
Old Jan 5, 2020 | 02:09 PM
jadmt's Avatar
JK-Forum Ambassador
I have installed 3 AEV 2.5's and none were offset enough to worry about. All were less than 3/16" off which is about as close as you can get. Remember when you are driving it is changing all the time.
Old Jan 5, 2020 | 02:34 PM
Stuffmax's Avatar
that’s good to know! Outside of recenter the axle is there any other benefit of upgrading the front track bar. I see a lot of guys comment how it improves handling?
Old Jan 5, 2020 | 03:21 PM
jadmt's Avatar
JK-Forum Ambassador
well stronger is always better. I have run both the Teraflex monster track bars front and rear and the Steersmart up front and both are much beefier than stock. I am running stock on my 2018 recon and don't feel the need for a stronger track bar as stock is fine for what i do.
Old Jan 5, 2020 | 03:29 PM
Stuffmax's Avatar
Appreciate the response. one thing is if it is strong enough for your activities. Another thing is if you noticed any improvement in handling with an upgraded track bar. Did you notice an improvement?
im sure strength wise the stock one is strong enough. It’s more a matter of will I get an improvement in driving
Old Jan 5, 2020 | 03:32 PM
saltman's Avatar
I recently installed the AEV 2.5/geo brackets on an 07 JKUR. Afterwards the front was off 3/4" side to side so it was 3/8" off of center. The rear was off set the same in the opposite direction with the AEV bar and bracket. I added an adjustable front track bar to center the front and left the rear. My jeep pulls to the left after alignment with the above.
Old Jan 5, 2020 | 03:37 PM
jadmt's Avatar
JK-Forum Ambassador
I put a lot of miles on. I have about 36000 miles in 2 years on my 2018 recon and live in Montana where we have 80mph speed limits and lots of fast twisty 2 lanes. I have had my current jeep to Moab 3X and I do not see the need. Mine handles very well and I doubt if I could really tell a difference hence I decided to keep the front one stock on this build. I do have the monster rear track bar but again if someone were to sneak in and replace it with a stock one I would not notice a difference in driving.
