What kind of difference did using the AEV Procal make?
Old Aug 13, 2013 | 11:27 AM
amick218's Avatar
Subd good info in here
Old Aug 13, 2013 | 12:35 PM
The Green Monster's Avatar
Originally Posted by jadmt
I live a couple of miles from AEV and Dave Harrington's brother invented the procal and he told me that it does in fact adjust the shift points to where they are supposed to be. If you are saying that you can not adjust them to where you want them you are correct but the Procal does adjust the shift points back to where they are supposed to be when adding larger tires.
Sorry, I should have been more clear. This is what I meant. Custom shift points would require a more sophisticated programmer as CJ7nvrstk suggests.
Old Aug 15, 2013 | 06:08 AM
groovebus's Avatar
My main issue was, why I was only getting 16 mpg on the hwy when the 3.21 gear was suppose to be so much better for milage. Then I realized my odometer was off, making the computer and my manual calculations off. Now I'm showing about 19mpg on the hwy. I am loving the smoother shifting.
Having OCD and a Wrangler is a dangerous combination.
Old Aug 15, 2013 | 06:16 AM
tcdawg's Avatar
Hand calculate your mileage now that you have the speedo set properly. See if your commuter is correct it not.
Old Aug 16, 2013 | 04:59 AM
robinson86's Avatar
Originally Posted by CJ7nvrstk
Procal doesn't adjust shift points.
A true tuner is what is required to adjust shift points.
True. What it does do is correct the false shift points caused by the RPM's changing due to the incorrect tire sizes. The transmission shift points are based off of the RPM's and of course the incorrect tire size will give a false RPM indication.
