What Lift do I want
What Lift do I want
Since this is my first Wrangler I am dumb to a lot of this. I have a 2dr 07 Rubi that will be driven mainly on the road. However!! A big However!!!: if I'm out and about and see a trail that I want to try I want to be able to try it. I also hunt and sometimes find myself somewhere that I could drive if I had the vehicle so I want the option. I don't know the difference between long arm lifts or whatever. I also read about pinion angles and such and am at a loss. A neighbor just put a BDS 3" on his and I am thinking I want a little more. Possibly a 4". I have read until my eyes and brain hurt about lifts and am still confused. I realize this is probably a hard question to answer but ...... what does everyone suggest?
what your pocket allows, we could tell you what to get, or what not to get, i have heard above 3 inch sus lift you need drive angle changes, track bar changes ect. like i said its up to your wallet not ours. good luck
That's what I'm talkin about. Is 3" a pretty decent amount that will allow good articulation and clearance? Or is 4" a better without having to worry about "drive angle " problems. Hey, Wayof Life, chime in here. What about the long arm kits? Like I said, I'm new to "Wranglers. I NEEEEEEED HEEEELP:toung:
What size tires will you be running? If you're not doing any serious offroading (rockcrawling, etc), then I wouldn't worry too much about a bigger lift and huge tires. I find myself in the same boat as you (but my intention IS to be off road, just nothing crazy at this time), so I went with 33's and a 2.5" BB. The 2.5 offers the ability to switch to 35's if I desire.
i also went with the 2.5bb from tera give plenty of clearence and a good stance, but your axles will be out of track alittle. check out the pics on my jk project page that is with stock tires i"m shooting for 33 toyo open countrys.
not a lot of big rocks on the coast.
I already have 33's stock. Maybe I'll only go 35's eventually, I just want to make sure I have good clearances???. (I work with a guy that has lots of land and he has trails but he said I couldnt come down there because he has ruts about 2 feet deep. He said I'll never make it since I'm stock. I have a new Rubi and don't like hearing that. I'll put out the bucks for a decent lift but I need to know what I need. Is a 4" too much or should I stick with a 3-3-5
JK-Forum Founder
