What should I do??????
Old Mar 2, 2011 | 11:27 AM
karben276's Avatar
Default What should I do??????
I am going to have a lift installed but am unsure which to do. I live in southwest VA where the pickins are slim as far as off road shops go. My local shop does a lot of BDS lifts and not much else. Other option is ti drive 2 hours away to Charlotte and have my pick of lifts(Full traction is the other lift im looking at).....only problem is that my JK is my DD so if I have any issues with lift or need work done then I may have to drive the 2 hours to Charlotte. What would you guys do? I probly wont do a ton of wheeling either, very minimal(too busy) Any advice would be great
Old Mar 2, 2011 | 11:37 AM
JK-Ford's Avatar
Read the JK-Forums. Ask questions and find out what you need to buy. Order the products from a JK-Forum vendor. Buy a case of beer and invite you buddies over for an instalation party. Enjoy your lift.
Old Mar 2, 2011 | 12:22 PM
RedJK2's Avatar
x2. I'm sure there are plenty of people on JK-Forum who would be willing to help, too.
Old Mar 2, 2011 | 12:30 PM
russcox1's Avatar
Just give Dave At Northridge a call and he will send you anything you may need.... then just get some friends over.. all my work with the exception of gears was done in my garage...
Old Mar 2, 2011 | 12:50 PM
Dronac's Avatar
A lift isn't hard to do at all. I put mine on by myself using the Project JK tutorial. I had never done anything more advanced then an oil change prior to it and it went on fine
Old Mar 2, 2011 | 01:12 PM
Pluke the 2's Avatar
lol, i never had done an oil change and i had to barrow all the tools to do the job and completed my install in three days....
Old Mar 2, 2011 | 01:14 PM
mattgt5's Avatar
x3 I have never installed much of anything and did mine with a fellow forum member in 6 hours. It was a breeze. i will never pay to have a lift done again. $500 minimum down the toilet
Old Mar 2, 2011 | 01:15 PM
jeeplife's Avatar
what shop is there over there i live in bluefield about 45mins away
Old Mar 2, 2011 | 02:43 PM
karben276's Avatar
Its RPM Off Road. They insist that a BDS is the lift for me. I dont think they do a lot of lifts from what I can tell. I live in Abingdon BTW.
Old Mar 2, 2011 | 03:03 PM
nthinuf's Avatar
Have you looked at the BDS line-up? And have they? The 2" is just coil spacers, nothing to it. The 3" is coils and CAM Bolts. The 4.5" has a bunch of fixed arms and brackets. BDS may be good for other vehicles, but kinda comes up short for JK lifts.
As others have mentioned, if you have the time, you should consider installing yourself. If you want to have that shop do it for you, at least look into other mfg's offerings. I'm sure you could talk that shop into installing another brand.
