Sponsored by:
Sponsored by:
What size should I go 285/75R16 or 305/70R16 ?
Old 05-15-2009, 05:48 AM
Default What size should I go 285/75R16 or 305/70R16 ?
Hi, it's actually my firts thread... I'm looking for set of wheels and tires for my JK. I've look to KM2 and Mickey Thompson MTZ. I Also looking at tire size, 285/75R16 or 305/70R16. Some one have and idea of what size should a I get? I'have stock suspension.
Thanks
Old 05-15-2009, 06:17 AM
Hbomb's Avatar
Originally Posted by Detn8RYellow
Welcome to the forum! The only difference between the two tires you listed is the 305 is about 3/4" (12") wider than the 285 (11.22") Other than that no real differences.. well according to the tire calculator I used anyways...
this will give you some idea of how much the 285's stick out.
Old 05-15-2009, 06:40 AM
RevyJKU08's Avatar
I am guessing you are going to use your stock rims as well. The wider 305 may rub lock to lock in the front end on tight turns. If you go wider you may need spacers on your stock rims to avoid rubbing. I believe the narrower tire 285's will be okay with out spacers.
Also, the 33 inch tall tire is the max you should go especially stock suspension. Also, check out the Search option on the site...you should get lots of information on tire sizes, lift sizes and spacers. Welcome to the forum
Old 05-15-2009, 06:53 AM
In fact I will put on Pro comp wheels 16''x8'' 4'' BS. So 305 should be ok?
Did some one have a 305 picture on 16''?
Thanks for answer
Old 05-15-2009, 07:08 AM
ZoSo-Green's Avatar
A friends JK w/ 305/70-16 MTZ's on a 16x8 wheel
It has a 2.5" RC lift.
Old 05-15-2009, 07:17 AM
Jeepin Dad's Avatar
This is mine with 285/75R16 on 16x8's with 4" b.s. I stick out about 3/8" past the flares.
Old 05-15-2009, 07:18 AM
titanus's Avatar
Hey Zoso, would you happen to have a perfectly lateral pic of your friend's ride? I'm installing a 3.5" lift and I'm thinking the 33x12.50x15 I'm going to install will look too small on my 4door JK.
Old 05-15-2009, 07:31 AM
scotlandjk's Avatar
x2 are you getting the aev lift?? im also considering 33's with this.
Old 05-15-2009, 08:25 AM
RevyJKU08's Avatar
Thanks for answer
You should have worries with rubbing with the 4" backspacing lock to lock. The wider the tire the more it will stick outside the stock flares. You should check into the Highway's act in your province what you are allowed for tires sticking outside the flares. I run a 4.5" BS aftermarket rim but have a 33x12.50R10 Cooper STT and they stick out about 1/2" outside the Stock Fenders.
If your tires stick outside the stock flares you will be rubbing on your flares with the wider tire in more extreme off-road flexing and thus a reason many get a Lift.
Old 05-15-2009, 08:37 AM
EHarris's Avatar
Do people with the 305 or wider tire have problems with road junk kicking up on the highway and finding its way into the vehicle. I run no doors for about 6 months so that would be a concern if I had passengers in the back seat.
Quick Reply: What size should I go 285/75R16 or 305/70R16 ?
