What size should I go 285/75R16 or 305/70R16 ?
Hi, it's actually my firts thread... I'm looking for set of wheels and tires for my JK. I've look to KM2 and Mickey Thompson MTZ. I Also looking at tire size, 285/75R16 or 305/70R16. Some one have and idea of what size should a I get? I'have stock suspension.
Thanks
Thanks
I am guessing you are going to use your stock rims as well. The wider 305 may rub lock to lock in the front end on tight turns. If you go wider you may need spacers on your stock rims to avoid rubbing. I believe the narrower tire 285's will be okay with out spacers.
Also, the 33 inch tall tire is the max you should go especially stock suspension. Also, check out the Search option on the site...you should get lots of information on tire sizes, lift sizes and spacers. Welcome to the forum
Hey Zoso, would you happen to have a perfectly lateral pic of your friend's ride? I'm installing a 3.5" lift and I'm thinking the 33x12.50x15 I'm going to install will look too small on my 4door JK.
If your tires stick outside the stock flares you will be rubbing on your flares with the wider tire in more extreme off-road flexing and thus a reason many get a Lift.
Do people with the 305 or wider tire have problems with road junk kicking up on the highway and finding its way into the vehicle. I run no doors for about 6 months so that would be a concern if I had passengers in the back seat.
