What is weakest link in the rubicon?
Old Apr 1, 2010 | 06:05 PM
rj'sjeep's Avatar
Default What is weakest link in the rubicon?
What is the weakest part of the 08 rubicon 4 drs? tie rods? What should I beef up before going to a small lift ( under 3 ") and 35's?
Old Apr 1, 2010 | 06:25 PM
Sharkey's Avatar
The driver.
Seriously, my money will be spent to strengthen the C's when I go to 35's. Maybe some moly axles as well. With 35's and some driver care though, I think you would be fine for quite some time.
Old Apr 1, 2010 | 07:00 PM
Hellbound13's Avatar
Tie rod, ball joints, steering stabilizer, trackbar brackets.
Old Apr 1, 2010 | 07:04 PM
Castalone's Avatar
Off Road Evolution axle gussets...
Old Apr 2, 2010 | 03:28 AM
spinlock's Avatar
The Rubi is perfectly suited for a sub 3" inch lift and 35s.
Just install the lift and tires and drive it. Other mods needed will become obvious to you.
Old Apr 2, 2010 | 04:07 AM
RubiDude's Avatar
A buddy of mine broke the tie rid after coming off one of those parking lot lanterns....dealer replaced it under warranty!
Old Apr 2, 2010 | 04:56 AM
codysanders's Avatar
c gussets are a must in my opinion other than that just get a complete lift and if you have a auto you will prob need a drive shaft for the front.
Old Apr 2, 2010 | 05:06 AM
Bustabizz's Avatar
Former Member
I would say the crappy factory driveshafts.
Old Apr 2, 2010 | 05:32 AM
redrockin7's Avatar
Probably could skid up some more stuff like evap canister and oil pan - don't think rubi has these skids?
Otherwise, you should be fine with a 2.5" lift (+ 1" body lift for example) and 35s for a while, if you have an unlimited.
If you wheel it extremely hard, then you should consider things like the c-gussets for the front axle, tacking the caps on your u-joints. Other stuff may break if you are wheeling hard, but fix it as it occurs IMO.
If you break some axle shafts for example, get some chromoly's but I surely don't think I'd go spend $600-1000 on shafts before I thought they were a weak link. Under moderate wheeling with only 35s, should last quite some time - however if you decide on 37s or something, then maybe consider them. Even then, many have wheeled 37s pretty hard on the D44 and had it last a while...
Driveshafts could need replaced at some point, but again wouldn't do so until I needed to as you could go a while with only a 2.5" suspension lift - they should be OK on unlimited until you damage them somehow or bind one up wheelin' it hard.
There is always something you *could* do to your rig and it might or might not save you (even modded parts bust now and then) hassle in the future, but IMO a 2.5" lift (+ 1" body lift) and 35s on a rubi, you shouldn't need to do much more right away unless you really plan to wheel it extremely hard then consider some of the above...
Old Apr 2, 2010 | 08:59 AM
JGP4JK's Avatar
I agree. It was named 4x4 of the decade for something!
