What will help me with out gearing
I'm having issues with hesitation when a take off from a stop. Especially when the A/C is on. I'm also suffering from having to down shift on the highway when I encounter hills. I'm only running 31s". I was thinking either a cold air intake or a flash tuner. any suggestions would be great.
I'm considering a left in the near future as well.
She is a 2012 JKU with the 3.6 and a 6 speed
A 3.6 manual, running 31" tires ?
NO, you don't need gears.
You need to realize that you aren't in a sports car. It's a brick with wheels. Any of the cheap bolt-ons or plug-ins will give minimal gains, but may be worth it to you, depending on your budget and expectations.
Next step up would be long tube headers, forced induction, and then a Hemi/LS swap.
I am running 315/70R17 with 3.6, and a six speed 3.21 gears. 33 3/4" tires. The only time I hesitate is first thing in the morning when it is cold. It has always done that thought. Even with the original tires.
I've never noticed this problem, but it's probably the way I drive. Regardless, others do complain about it, so a company has come out with a fix. Assuming that there's not something mechanically wrong with your Jeep and you're just one of the folks who is sensitive to the hesitation, this may solve it for you ...
Sprint Booster SBJE1012S - SprintBooster Selectable Power Converter for 07-12 Jeep® Wrangler JK, Wrangler Unlimted JK, Grand Cherokee WK/WK2 & Liberty KK with Automatic Transmission - Quadratec
You most likely have 3.21s, regearing to 3.73s would probably help and would work well with 31" tires.
I have a 2011 with the optional 3.73. Have zero problems with hesitation at take off. Again, it's not rocket ship but I haven't had any complaints. If you bought brand new and didn't opt for the optional 3.73, you have 3.21.
