Wheel Help...last time :)
Old Apr 22, 2013 | 01:00 PM
WVUFAN18's Avatar
Default Wheel Help...last time :)
I am going with an 18 x 9 wheel ( yes, I am aware of tire cost). My question is the vendor claims I can get the wheel with 5.0 or 5.5 BS. I live in PA so need to keep the tires under the fenders as much as possible ( not supposed to stick out at all). I am going to run 285 70R 18 tires. I have a 2011 Rubicon. Am I safe to go with the 5.5 BS or will I have clearance/rubbing issues? Is it safer to go with the 5.0? Keep in mind I want the tires under the fender as much as possible. If i were to go with the 5.5 on the wider 9" wheel with 285s how much could I expect the tires to stick out from the fenders? Sorry for asking but I went to two tires shops in my area that were no help at all. I dont think they knew how to spell JEEP. Thanks in advance for your help.
Old Apr 22, 2013 | 01:50 PM
Jonathan_JK's Avatar
Check out the wheels that AEV offers They have the backspacing your looking for to run that tire size without coming out of the fenders.
Old Apr 22, 2013 | 04:21 PM
WVUFAN18's Avatar
Default wheel help
I think I've come to the conclusion my tires will stick out some based on the wheels I want. My real question is 5.0 or can I get away with 5.5 BS?
Old Apr 22, 2013 | 04:40 PM
AEV is 5.2 BS. If you use 5.5 just remove the front air dam and you should be good. If not you can always add a washer or 2 to the steering stops.
