Wheel off-center ESP TCS Please Help
Old Feb 26, 2009 | 05:08 AM
cyberbrain's Avatar
BAS is brake assist system.
Old Feb 26, 2009 | 05:10 AM
roguejk's Avatar
congrats on doing it yourself you just saved a few dollars and have gained a lil more confidence, thanx to this forum i have gained the confidence to tackle my axle shafts and wheel bearings ( once i can afford the parts)
Old Feb 26, 2009 | 05:20 PM
chuck45's Avatar
I feel the same way. To me part of owning a Jeep is doing as much as you can yourself.
I recently did the front and rear axle shafts. With the help of folks on the forum and working carefully it's no big deal.
Old May 9, 2009 | 05:28 PM
blln314's Avatar
I did the steering wheel alignment and I did the batt disconnect. The lights are still on could there be another cause for the problem?
Old May 10, 2009 | 07:35 AM
PatAck's Avatar
Im in the same boat as you.
After wheeling my steering wheel was off center... the next day, while turning onto the thruway my dashboard lit up lick a Christmas tree.
I checked for visual damage, impact spots and such... nothing. So i just re centered the steering wheel and the lights are still on.
Im going to take it to the dealer (just over 1000 miles) to see what they say... if there is a charge involved i plan on doing the work myself... but i should have a better idea whats bent or possibly broke
Old May 10, 2009 | 08:30 AM
chuck45's Avatar
I used to have to recenter my steering wheel after almost every wheeling trip. I'm doing it far less since I installed te RockKrawler HD Tie Rod. I'll bet if I replace the factory drag link recentering will be a rare occurance. The factory tie rod looks beefy but it's a typical undersdesigned and underbuilt bean-counter inspired Jeep part. I hope somebody decent buys Jeep and starts to build them right. If they went and locked at the axle bracketry on a Dynatrac or Currie RockJock axle they'd know what to do on axles for instance.
Old May 10, 2009 | 08:49 AM
0311sgt's Avatar
I would be willing to bet the tierod is bent. if the it is the computer lights up the BAS ESP lights with an " ALIGNMENT " code in the computer. in other words because the tierod is bent your alignment is off. The factory tierods are flimsy as all hell. At east coast JK fest i bent my tierod, all the lights came on, as soon as i put the new one on,(which was in the parking lot of the OR park) and hit the highway all the lights went off. It is the next thing on my upgrade list as soon as the wife approves it
2007 JK Unlimited 6speed w/4.11 Gears
3" BDS lift
33x11.5x16 soon to be 35x12.5x16
JKS quicker disconnects
Rough Country Dual Steering Stabilizer
RocKrawler High Clearance Adj. Lower Control Arms
RocKrawler Lower Control Arm Mounts/Skid Plates
Engine/Oil pan Skid Plate by Skid Row
Skyjacker Adj. rear track bar
Skyjacker Brake line Ext.
Custom front winch bumper by RoundStar OffRoad
Mopar offroad rear bumper
Plenty of rock rash from good days on the trail
“A bad day on the trail, is better than a good day in prison.”
Old May 10, 2009 | 09:05 AM
chuck45's Avatar
Yup, I've spoken to several people who were having to recenter all the time who do it far less after they've replaced the factory tie rod. I know from expereince that once they bend they only get weaker and worse. I'll bet I never have to do it when the factroy drag link goes away too.
