wheel offset?
Old Jun 21, 2011 | 07:18 AM
ismai1's Avatar
Default wheel offset?
295 70 17s are rubbing. I'm planing on new wheeps opposed to spacers. What offset do I need?
mikach28's Avatar
4.5 backspacing
Old Jun 21, 2011 | 07:27 AM
Wandell's Avatar
Loved
Depends on what lift you have and where the rubbing is. But a 9 inch wide wheel with 4.5 inches of BS appears to be the most popular.
Old Jun 21, 2011 | 07:50 AM
wayoflife's Avatar
JK-Forum Founder
Originally Posted by mikach28
4.5 backspacing
what he said, 4.5" of back spacing is what you want.
Old Jun 21, 2011 | 08:58 AM
Davep22's Avatar
Just to add a little more clarity - backspacing and off set go hand-in-hand to some degree but are not the same thing.
Some sites and stores (mostly those servicing all types of cars, not just off road/jeeps) will use offset more often.
Others, especially off-road focused sites will give back spacing.
For your jeep, if you go with an 8 or 9" wide rim, you will want to have 4.5" or less (ie, 4.25", 4" etc) Backspacing. Note that 4.5" backspacing on a 9" wheel will have your tires extending beyond your fender flare by about 1.5" - if you were go use a wheel with 4" of backspacing, they would stick out another .5"
As for the offset, a 9" wide wheel with 4.5" of backspacing will have a -12 offset.
An 8" wide wheel with 4.5" of backspacing will have 0 offset.
Hope this helps!
Old Jun 21, 2011 | 09:47 AM
TURTLECON's Avatar
If I'm not mistaken, positive offset will bring your wheels closer in, and negative offset will push them further out.
Old Jun 21, 2011 | 11:12 AM
Third Wave's Avatar
Default Thanks
I was trying to figure out the exact meaning of Offset -12, 0, 10 etc as opposed to backspacing.
Now I know.
Why don't wheel companies just list the backspacing and help us out?
Old Jun 21, 2011 | 12:31 PM
Wandell's Avatar
Loved
I know, right. To me, backspacing is just much easier to understand and visualize.
Old Jun 21, 2011 | 12:42 PM
CerOf's Avatar
so the rugged ridge rims are 4.75" back spacing. Is this fine for a 12.50" width tire?
Old Jun 21, 2011 | 01:06 PM
TURTLECON's Avatar
For a JK? Yes.
