View Poll Results: What Wheel Size
17x8
22
28.57%
17x9
55
71.43%
Voters: 77. You may not vote on this poll
Wheel Size
I am about to orde some wheels and have decided on the pro comp 7189. I want r17. I will be running a 35x12.5 tire for now with the possibility to may be go to a 37 inch one day. would you get an 8 or 9 inch rim.
It might not be relevant and its not really an answer to your question but the larger you go the more they will stick out of your fenders and you have the sahara, so all the road or off-road debris will be trown on your fenders and the paint will chip fast...
just my 2 cents, if it is important to you
The determining factor should not be width but rather backspacing. With 35s, you generally want no more tha 4.5" backspacing & 4" is preferable. With 37s, you will want 4" or less backspacing. Otherwise, you have to adjust your steering stops substantially in order to avoid rubbing your tire on your lower control arms and frame rail.
So, if you can get either with 4" or less backspacing, then, if you do rocks, you'd prefer the 8" because there would be slightly more protection of the wheel when aired down.
If you don't do rocks, the 9" will allow a flatter treadwear on the street & better handling.
