View Poll Results: What Wheel Size
17x8
22
28.57%
17x9
55
71.43%
Voters: 77. You may not vote on this poll
Wheel Size
Old Oct 1, 2009 | 07:24 AM
Alf1096's Avatar
Default Wheel Size
I am about to orde some wheels and have decided on the pro comp 7189. I want r17. I will be running a 35x12.5 tire for now with the possibility to may be go to a 37 inch one day. would you get an 8 or 9 inch rim.
Old Oct 1, 2009 | 11:34 AM
Alf1096's Avatar
So far more have gone with a 9inch rim. I was leaning twoard the 8. So why are you guys going with 9.
Old Oct 1, 2009 | 11:37 AM
horwitzs's Avatar
Most 12.5" wide tires have specs that say 8 or 8.5 wide wheels are the bare minimum.
The 9 would put you more in the middle range of what the tire was designed to fit on.
Old Oct 1, 2009 | 11:38 AM
JR-WRANGLER's Avatar
It might not be relevant and its not really an answer to your question but the larger you go the more they will stick out of your fenders and you have the sahara, so all the road or off-road debris will be trown on your fenders and the paint will chip fast...
just my 2 cents, if it is important to you
Old Oct 1, 2009 | 12:21 PM
08leocon's Avatar
Originally Posted by planman
The determining factor should not be width but rather backspacing. With 35s, you generally want no more tha 4.5" backspacing & 4" is preferable. With 37s, you will want 4" or less backspacing. Otherwise, you have to adjust your steering stops substantially in order to avoid rubbing your tire on your lower control arms and frame rail.
So, if you can get either with 4" or less backspacing, then, if you do rocks, you'd prefer the 8" because there would be slightly more protection of the wheel when aired down.
If you don't do rocks, the 9" will allow a flatter treadwear on the street & better handling.
I went with tires spec my 35x12.50x17 BFG Km2's suggested 8-10 inches wheel, i went with 9 as it was in the middle,but that was just my choice!
Old Oct 1, 2009 | 12:26 PM
Machine154's Avatar
Might as well go bigger to start and give yourself some room. I got 33x13.5's and didn't hesitate to get 10" ones.
Old Oct 1, 2009 | 01:25 PM
Alf1096's Avatar
I am looking at the pro com 7189 and the 17x9 have 4.75 bs will this be ok with a 35 and 37 inch tire.
Old Oct 1, 2009 | 04:39 PM
nangulator's Avatar
I have 17x9 soft 8s with 5 inch b.s. and 35x12.5x17 km2s and no rubbing issues even aired down to 14psi (properly centered rear axle with adjustable trak-bar)
Old Oct 1, 2009 | 05:39 PM
Alf1096's Avatar
Now I am just confused 4.75 will be ok with 35's but not 37's. What is the ideal bs for 37's. I will really probably only ever run 35's. 4.75bs is ok for 35's right.
Old Oct 1, 2009 | 06:05 PM
08leocon's Avatar
I have the 8179 17x9 4.75 bs with 35's no issues, i cant speak for 37's
