Wheel Size
Old Jun 21, 2009 | 02:49 PM
Seanbmc's Avatar
Default Wheel Size
I am looking for some new tires/wheels. I read that a 4.5in backspacing is best, but the cragar soft 8s in 16" are either 4 or 5. Which of the following would work best, I have a 2.5" lift.
Tire- BFG All Terrain KO 315/75/16
Wheels - Cragar Soft 8s
16x8 5 inch BS
16x7 4 inch BS
17x8 4.5 inch BS
Old Jun 22, 2009 | 04:06 PM
Seanbmc's Avatar
Question
After some more looking around I dont think costco will even mount the 315 on the 16x7 rim. BFG suggest at least an 8" rim.
Will I have any problem with the 5" backspacing on the 16x8 rim? I have a 2.5 lift and would like to go without spacers if possible.
Sean
Old Jun 22, 2009 | 04:29 PM
Seanbmc's Avatar
Originally Posted by Detn8RYellow
Went through that thread and only found backspacing recommendations for running a 12.5 wide tire. I believe the 315/75/16 tires is 12.2 wide. Id rather not just guess that the difference will 'work' though. Thanks
Sean
"Q: What back spacing will I need on my wheels in order to clear 12.50 wide tires?
A: I would recommend that you do not exceed 4.75" of back spacing and even at that, you may still have some minor rubbing up front at a full turn. Also, I would recommend that you do not go any less than 3.75" as anything less would cause your tires to stick out very far past the fender flares. Any back spacing within this range should work out great."
Old Jun 22, 2009 | 05:05 PM
azeeb's Avatar
I'm hopefully going to put some 16x8 w/ 5" BS on this weekend. With 315/75/16 tires. I'll let you know how it goes. If not this weekend then next for sure.
Old Jun 22, 2009 | 06:01 PM
SuperJK's Avatar
I would suggest going with the 17x8 with 4.5" bs... I had the 16x8 w/5" bs and had some rubbing issues with the 12" wide tire..
I have since changed wheels and now running the 17x8 Cragar soft 8 w/4.5" bs and a 12.5" wide tire and no issues at all...
Old Jun 23, 2009 | 04:24 AM
azeeb's Avatar
Where were you getting the rubbing?
Old Jun 23, 2009 | 12:44 PM
Seanbmc's Avatar
x2 on the rubbing. Is it turning or full flex stuff? What lift setup do you have and what type of 35" tires were they?
Sorry for all the questions, I really do not want to go 17". The higher price of rims/tires throws the upgrade way above my budget.
